Old 07-13-2005, 11:29 PM
More1951 More1951 is offline
Re: Re: Re: 95 Blazer loss of power
Originally Posted by BlazerLT
You see where the metal inside has been washed clean? You need to replace your CPI injector and the nut kit.
That is the cause of your performance problem.
Excuse my for this question: the injectors are inside the body of the Nut Kit? (named “spider” in my city). Thank you
Oh!., This question was previous to your last answer. You had been advanced to the answer. I understood your technical instruction perfectly. The black deposits are relatively "normal" and the areas where the surface are cleans indicate that there is a loss of fuel for the system. I already saw your pictures and instructions in http://www.s10forum.com/forum/showt...cpi+replacement.
A thousand thank you.
Old 07-14-2005, 01:04 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
No problem.
As you will see in the link I gave you, you will see the new white lines which supply fuel to the injector. These are called the "Nut Kit".
The CPI injector is called the spider.
Replace both and make sure your mechanic cleans that EGR port that I showed you in that link.
What you will need to replace:
CPI Injector (spider)
Nut kit
Upper plenum gasket (don't reuse the old one)
Also, change your oil as soon as possible. The fue leaking out of the injector will go into the oil which will thin it out and cause oil related bearing damage.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-14-2005, 10:24 PM
Ok, BlazerLT. Everything understood.
Alone that the pieces are quite expensive in my country; for example, the CPI (spider) it is difficult to get and it costs between 450 and 650 dollars, and the hoses (white as those of your car) are not gotten.
On purpose, the mechanic carried out the verification indicated in your link with the old kit that is still installed, opening the switch and indeed there is leak of fuel. The exact place of the leak was difficult to observe with the installed kit, seemingly it is between the regulator and the body of the spider or possibly for some of the hoses of the injectors, in the place where they emerge of the body of the spider, but there is not leak properly for the hole of the end of the regulator.
I am in the process of getting the pieces for the repair. I will change the oil, the oil filter and the upper plenum gasket (¿Is the upper plenum the same dynamic chamber?).
Thank you.
Old 07-16-2005, 08:31 AM
BlazerLT's Avatar
AF -Advisor
I don't know what you are asking, please clarify.
Old 07-17-2005, 11:33 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Perhaps by "Dynamic Chamber" he means if the upper plenum icorporates the IMTV?
Old 07-20-2005, 04:15 PM
Ok. It is not very important. I meant that the compartment where are the injectors and the Nut Kit is called the “dynamic chamber” by the mechanic and I wanted to know if it is the same thing the "upper plenum". Thank you
Old 07-20-2005, 07:43 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Yes
Old 07-21-2005, 07:33 PM
Repairs and changes carried out:
Was replaced the CPI, Nut Kit, gasket, motor oil, filter oil, distributor rotor and spark plugs.
Now the engine responds with the appropriate power.
However, the engine presents irregularity in the minimum march (ralenti) and also when it ascends around 2000 rpm; seemingly as if a spark plug didn't work, but the spark plugs and the wires work correctly.
The mechanic cleaned carefully and correctly the surface of the upper plenum and he installed the gasket but he didn't apply it seal and I have the impression that air can be entering for the assembly. (The box of the new gasket contains a seal tube). What do you think about that?
Thank you
Oh!., as you can observe in the picture that I sent (link below), this engine doesn't have EGR valve; where the EGR valve should be, there is a cover with two screws. Anyway, the hole was cleaned completely.
http://files.automotiveforums.com/ga...hp?photo=45100
Old 07-21-2005, 07:51 PM
blazee's Avatar
blazee blazee is offline
Problem?
Link to picture doesn't work. Here's the pic:
Old 07-21-2005, 08:06 PM
Thank you blazee for your help. I already corrected the link to picture.
Old 07-22-2005, 12:03 AM
rlith's Avatar
Was replaced the CPI, Nut Kit, gasket, motor oil, filter oil and spark plugs.
Thank you
Unless the EGR was deleted from the ECM (unlikely) that may be causing your stumbling acceleration.... The egr is there for a reason. You can restrict it, but it shouldn't be removed!
Old 07-22-2005, 02:52 AM
This absence of EGR is original of factory of the vehicle. It has not been altered.
Old 07-22-2005, 04:56 AM
rlith's Avatar
I've never seen a CPI engine without an EGR manufactured for canada or the US...
Old 07-22-2005, 05:40 AM
This vehicle is originally assembling in Venezuela and import to Colombia.
Please: Which is the torque of the screws of the upper plenum?. Does the upper plenum gasket need seal? Thank you
Old 07-22-2005, 05:43 AM
rlith's Avatar
8 ft pounds torque in a circular (not cross) pattern. Start at 7 o'clock and work your way around. No, the gasket doesn't need sealent. Just drop the gasket on and tighten bolts.
