Old 07-10-2005, 07:34 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Safe to Remove Fender Flares?
Originally Posted by 3wbdriver
Hey Jethro, there will never be another like Dale. I run a black street stock Camaro dirt track car, with the #3WB on it, as a frank admission that I'm a wannabe. Do you still have that hitch cover, and if so would you be willing to part with it?. I haven't been able to find a decent Earnhardt cover for my ride. And Blender, I love the look the flares put on my 2wd Silvy, but I also went with an 8" wide rim to fill the added width out. I'll go with a 245 or 255 tire when the originals wear out.
That was my plan... widen the track a little without having the tires/wheels sticking out from under the body. Let us not forget the valuable lesson Pontiac taught us in the late 90's..."Wider is better.."
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-10-2005, 08:54 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
3wb, Nought, Nada, Never.... I widdled my collection down a little but my shelves will never get smaller from here on out. Someone tried to bust my hitch lock and if I would have found the shithead I was thinking lead poisoning . Just thinking...
Check out my gallery, this is the one you want....
Old 07-10-2005, 10:10 PM
3wbdriver 3wbdriver is offline
Forgive me PULEEZE jethro!!! As a fellow Earnhardt follower, I should have known better than to even think you would part with any of his stuff! A thousand apologies!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Blender, when you get ready, I went with an 8" wide rim on a 3 5/8" offset. That put my stock 235's within a half inch of flush with the outer lip on the flares. They actually had the sidewalls about 1 1/2" outside of the stock fender. I would guess it widened the overall track of the truck by about 4".
As to your gallery jethro, that's the one I want, but who makes it?
GAS IT TIL YOU SEE GOD, THEN TURN LEFT!!!!!!
Old 07-10-2005, 10:52 PM
4" is a lot of extra track... but if you added 2" of width to each tire, then I think you are correct, and I bet it would corner a lot better like that... especially with my truck's long ass
Old 07-11-2005, 12:13 AM
White Lightening's Avatar
White Lightening White Lightening is offline
Re: Re: Safe to Remove Fender Flares?
Greetings Blender and 3wb,
Just curious - if you added tires that are 2 inches wider - would you have added a total of 2 inches more to the track width? My theory is that rim - when widened - expanded on both sides of hub circle center doesn't it (1 inch toward flare and 1 inch toward inner fender on each tire? I guess I was thinking that all the rim and rubber don't go outward as sizes change. Tommorrow - I'll measure my factory 8 inch rims with the factory 20's on them and see what my track measures.
What is the standard width?
Thanks.
White Lightening
Old 07-11-2005, 12:38 AM
jethro_3's Avatar
3wb, no prob.. I appreciate your asking and no hard feelings taken. Glad someone knows how I feel. "The Man" I looked and there were no markings and the local store I bought it from went under due to loss of sales.
Old 07-11-2005, 08:14 AM
Good questions lightning. I think the stock rims were only 6" wide, and had a 4" offset (usual factory standard). My new rims were 3 5/8" offset and 2" wider. I didn't think it would make that big a difference until I saw them mounted, even with the stock 235/75-16 tires. I was quess-timating the track increase, but if you look in my gallery, there is kind of an evolutionary history of the truck from day 1 (pardon the dupes), and there is a pretty obvious difference in the track stance, before and after. I'm not being defensive, just trying to justify what I claimed. Yes most of it is probably sidewall width difference, due to the rim change, but ya gotta admit, it made a noticable change in the outward appearance of the rig. And yes, you are correct on the wider tire assumption.
Old 07-11-2005, 10:37 AM
brumleveb brumleveb is offline
So, do the factory wheels/tires extend beyond the fender (without flares) on a factory 4 x 4?
Old 07-11-2005, 11:24 AM
I just measured my Goodyear 20 inch tires with the 8 inch rims. My track width (I used sidewall to sidewall because with the low profile - there wasn't a great deal of difference between sidewall and tread widths) and it came up to 79 inches. I get just a slightly greater width at tire than I do at middle of fender width.
In my previous post I forgot to consider that my tires/wheels are low profile with a greater "inset" of rim rather than an outset (nature of my rims). Most of my rim width is inset from the center - instead of outset. So yours could easily be wider still than mine if you have more outset - which I would guess you'd almost have to have. My tires have very little sidewall buldge.
. . .>>>>> . .White Lightening . .<<<<<
More pictures???
Link below shows them & a list of features and options on this 2wd SS
V.H.O.
http://files.automotiveforums.com/ga...ite+Lightening
Old 07-11-2005, 11:34 AM
Also, the standard factory rims on most of our trucks are 6.5"
Old 07-11-2005, 03:41 PM
brumleveb, I haven't seen any 4x4 factory tire/wheel combos sticking past the fenders, but the flares may be intended for some of the more aggressive combos, to keep them 50 state legal.
Old 07-12-2005, 09:31 AM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
I just put some stock flares on my 2wd and it looks awesome. And as mentioned before, it's easy.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 07-13-2005, 10:33 PM
spudglo08 spudglo08 is offline
Send a message via AIM to spudglo08
Those flairs should peel right off when my mom crashed my dads HD the flare came off without any indication it was there.of course it snaped off the rivits also
Old 07-19-2005, 02:39 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Hmmm....I'm looking for some smooth painted flares.
I might even have a set of the black grained ones to swap for even.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
