Old 08-21-2005, 12:56 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: Re: Re: mpg?
Originally Posted by AlmostStock
Lower gears have a higher number and would give you worse gas mileage.
Lower gears = higher number. Higher gears = lower number.
So what you are trying to say is that when you have something like 4.10 you get good gas mileage and when you have 3.23 or something like that you get bad gas mileage. Do you mean that with lower gears you can reach higher speeds and with higher gears you get lower speeds?
Old 08-21-2005, 01:12 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: mpg?
With lower gears you can reach high speeds quickly, but you'll have a lower top end.
With higher gears you won't reach high speeds that quick, but you'll have a broad top end.
In the end, higher gears will get you better fuel economy since you won't be revving so high when you're cruising down the highway.
Usually "mpg" isn't something you mention in the same conversation as muscle cars. It's kind of like taboo in the muscle community. If you wanna drive a car like this, there are strings attached. And if you complain about the fuel mileage it gets, what the hell are you doing driving it then? That's the way I see it. If you like your dog, you give it food and take care of it. If you like your V8 you give it gasoline and enough to keep it running. Same thing.
My Mopars
Old 08-21-2005, 02:02 PM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Re: mpg?
i dont have a muscle car. and higher gears give u better acceleration and bad top end and bad gas milage and lower gears give u worse acceleration good top end and better gas milage.
Old 08-21-2005, 07:05 PM
BleedDodge's Avatar
Re: mpg?
That is completely incorrect.
My Mopars
Old 08-21-2005, 09:09 PM
Re: mpg?
so right now i have 3.27's on my car and when i get 4.10's im gonna get better gas milage?
Old 08-22-2005, 02:33 PM
Re: mpg?
I'm sorry Bleeddodge but I totally agree with neatofrito. A higher rear gear with shorten every gear. With 4.10's the rear tire spins 1 time for every time the driveshaft spins 4.10 times. That means the driveshaft would spin more with 4.10's to reach the same speed as something like 3.27's. Having higher gears is a mechanical advantage used to deliver the power of the engine in a shorter span. I'm sorry to say you have it backwards. Lower gears strech out that span with 3.27's you could reach a higher speed, have better gas mileage but your car's acceleration wouldn't be as good as with 4.10's.
Old 08-22-2005, 02:47 PM
NOVA71's Avatar
NOVA71 NOVA71 is offline
Mines69Olds is 100% correct. Your best gas milage would be a numerically lower gear like 3.08 or 2.73.
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 08-23-2005, 11:50 AM
MrPbody MrPbody is offline
AF -Advisor
Re: mpg?
Yup, therein lies the rub... Due to myth and superstition, shadetree mechanics, and all the other buzzing in your ears, the definitions of "higher" and "lower" have gotten lost in the shuffle.
A "lower" ratio (key word here) indicates the "driven" gear will turn a LOWER number of turns based on the number of turns by the "drive" gear. A "4.10" is a good example of a "low" street gear. A "higher" ratio will take fewer turns of the "drive" gear to make one turn on the "driven" gear. In this case, the "drive" gear is the pinion and the "driven" gear is the ring. "High" gears are sometimes called "taller" or "highway" gears. A "3.08" is a common "highway" gear for GM cars.
A "higher numerical" ratio is a "lower" ratio. We didn't really use this terminology until the '80s, though it's been around as long as mathematics. it CAN be confusing...
FWIW
Old 08-23-2005, 04:20 PM
Re: mpg?
Ok Ok... So nobody was really wrong we were just not on the same page. Sorry Bleeddodge you were right. Thanks MrPbody for helping put everything into perspective. I appriciate the help and learning a new thing or 2.
Matt
Old 08-23-2005, 06:00 PM
Re: mpg?
i was thinkin the same thing.
