Old 07-11-2005, 02:01 PM
Hybrid1990crx's Avatar
Re: What oil filter for B16A?
yeah 30 bucks is way too much for an oil change when I can do my own for 15-20 in less time than at a dealer anyway.
Old 07-11-2005, 02:09 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
I'd take a $30 oil change for my wife's car over the $60 one the VW dealership charges... they claim that they ship their Castrol synthetic oil over from Germany. I still haven't changed the oil in that car... don't ask...
BTW, I use Purolator and if I had a B16 I'd probably use a Purolator filter on it too.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 07-11-2005, 02:14 PM
im rocking a mobile 1 on the b16 right now. not really my first choice of filters due to the price, but atleast I know I can trust it. The filter itself was like 13 bucks. Im acutally due for a oil change right now.
Old 07-11-2005, 02:20 PM
Re: Re: What oil filter for B16A?
me too... driving at least 80 miles a day racks up the miles quick... 300 miles to 200,000 on the cluster... second engine to my knowledge rocking about 1/2 as many miles as the chassis...
BTW, if you take a Bosch filter and put it next to a Mobil 1 they are practically identical (except for the logo of course)...
2010 Honda CR-V EX
Old 07-11-2005, 02:22 PM
does surprise me. most higher end filters are made by a company called Whicks, im not sure if thats the correct spelling.
Old 07-11-2005, 02:35 PM
crv-tec crv-tec is offline
See, I never remember what the serial number of the filter is. I just take the filter off, run up to the store and compare it...
'nuff said
Old 07-11-2005, 03:02 PM
you "compare" it? WTF is that suppose to mean? Are you retarded? What if the seals are different or the threads and you cant really tell, and then you put it on and drive 20 miles and the fucking thing falls off and you loose oil pressure and then blow your motor. that is really the dumbest thing ive heard today.
Old 07-11-2005, 03:27 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
only on AF will you find an oil filter argument.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 07-11-2005, 06:29 PM
How is it dumb, when the fucking part number is on the oil filter itself? And not to mention most stores actually have a little book in the oil section that lists engines, and what filter (including what seriel number for the filter that fits that engine).
So please, I would like to know how having a part in your hand at a part store, to compare the old part that was on the car to a part that is going on the car, is a dumb idea? Please do explain, as its not a bad idea...
'nuff said
Old 07-11-2005, 08:58 PM
Kven's Avatar
Kven Kven is offline
Wix They make the some of the Napa filters also(Gold and another one), and many other OEM filters. the AC Delco's are similar to the Wix design.
when you have the part in your hand, you see nothing but the outside. the difference can be in the filter element, amount of filter, style and position of bypass valve, etc. "never judge a book by its cover" is what i think hybrid1990crx is trying to say.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 07-11-2005, 09:02 PM
Kven's Avatar
btw, in the link i posted from the prelude site it talks about the Bosch isnt recommend, but the Mobil 1 is:
Originally Posted by NTPOG
The Mobil 1 oil filter is well constructed and a decent filter. Unfortunately, I'm not been able to get my hands on a stock spec'ed Mobil 1 filter (but have taken apart a few oversized ones). However, I have been able to discern that it's made on the same line as the K&N filter, but will a media that is slightly better at filtration. Based on testing by others I still think this is a really good filter.
While both the STP and the Bosch filters were at one point good filters, they are now manufactured off shore of sub-standard parts. The filter assemblies tended not to have even pleats and generally less media than other comparable filters. There was also a complete lack of a well functioning by-pass valve. With most filters there is an obvious and discrete by-pass valve, but with these filters the can spring and the by-pass valve are the same. The real issue is that in order for the filter to properly by-pass the entire filter assembly would have to move down during use. That is actually not possible with filter assembly properly seating into the anti-drain back valve. This means that the by-pass will effectively never work. In the center of the of picture below you see the filter assembly (top) and the can spring/by-pass valve (bottom). (The can spring / by-pass valve would flip over and into the filter assembly.)
1988 Honda CRX DX
Old 07-11-2005, 09:11 PM
exactly
