Old 07-16-2005, 08:29 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 91 camaro surging
BG is a company that sells products for automotive applications. their 44k is a fuel system treatment that you pour into the tank. it removes varnishis, carbon deposits, and cleans injectors. ive used it in all of my families cars and also done the BG induction service, and they make a drastic difference. i did both to the IROC when i brought it home, and also did the throttle body service, (man the nasty black shit that came outta that thing was scurry) and thats one of the reasons i wound up parking her on the back lot fence that night. throttle responce was frickin sick. (in a good way)
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-18-2005, 02:57 AM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
If you step on the gas and it goes for a while hte nbogs down like you are tugging a buick then its probably a bad fuel pump. thats what my car had w/ bogging. It practically had a heart attack whne I turned on the A/C literally jumping around like a person just learning a tsickshift would drive. have a mechanic check the PSI of it if you can't do it yourself
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 07-23-2005, 08:42 PM
CRUZIN91 CRUZIN91 is offline
Re: Re: 91 camaro surging
I check the fuel psi, while running was 5 psi, I read it was supposed to be 9-13 psi. Their is 2 fuel lines going to the tbi, does it matter which one I use? Thinking maybe bad fuel regulator.
Thanks again for all the help!!
Warren
Old 07-23-2005, 08:46 PM
89IROC&RS's Avatar
yes it matters, one is the input line that will be at full pressure, and the second line is the return line, after the pressure regulator and the fuel is under far less pressure.
the big line is the input line, the small line is the return line.
Old 07-23-2005, 08:55 PM
Ok thanks, there was 2 different size lines and the fuel psi gage only fit on the big line, just wanted to make sure, mmmm sounds like fuel pump now......
Old 07-23-2005, 09:23 PM
89IROC&RS's Avatar
did you ever change the fuel filter????
Old 07-24-2005, 04:07 AM
Ya I changed the fuel filter out, was trying all the simple stuff first.
Old 07-24-2005, 03:24 PM
89IROC&RS's Avatar
ok couldnt remember
Old 07-25-2005, 08:03 PM
Re: Re: Re: 91 camaro surging
UPDATE: Well I put a fuel reg. rebuild kit in and still have same problem, psi is still only 5-6 psi while running.
Old 07-25-2005, 08:27 PM
5-6 psi?! It should bel ike 40-50 psi! (Atleast that what it is for mye v-6 i would sasume it should be the same, )
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 07-25-2005, 09:00 PM
Well this is a throttle body, tbi. at www.cfm-tech.com thats what they say it should be 9-13. I think for a multiport its 40 -50. I guess I'll hook up my gage to my 88 chevy truck, it has a tbi also and see what it reads.
