#16
Re: valve clatter
It's possible that the missing bolt in the oil pump housing caused wear in the pump, which lowered your oil pressure - causing some bearing problem.
Sorry, just guessing Since he changed spring color, I wonder if the spring color has to match a specific idler pulley. Since the two springs have different tensions, there may be two idler pulley assemblys that are not interchangable. You might check to see if there are two different part numbers for the idler pulley assembly.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
#17
Re: Re: valve clatter
The garage is halfway cleaned out--at least some good may come of this...;-) |
#19
Re: valve clatter
Probably wouldn't. But I have heard of stranger things causing problems. Just tying together the loose ends of the belt replacement. It is either the oil pump not functioning correctly and causing a bearing to fail, or something in the belt path. Nothing else was touched, that I know of. Just looking at everything in the belt path with fine-toothed comb.
Why would they sell him a green spring? Because the guy at the parts counter didn't know better. I'm not saying this is a problem, just that this is what I would look at if this was my engine.
#20
Re: valve clatter
I called a guy at my local Toyota dealer and he said that there is only one spring available and one idler pulley assembly available. I guess this means they found a lower tension spring was better for belt life or something.
#21
My husband says, just for argument's sake, what if that were true--if the spring was too tight or too loose, how would that cause the knocking noise? And why would Toyota sell him that spring, knowing that he had a green one? The garage is halfway cleaned out now, so at least some good will come of this! ;-) |
#22
Re: Re: Re: valve clatter
Oh, now it showed up--sorry about the double-posting. Anyway, thanks for your help, Brian, and thanks for saving us a call to Toyota! |
#23
Re: valve clatter
Good luck sorting it out.
#24
Bev |
