#16
Re: overheating
oh and dont use tap water in your radiator. will make stuff corrode, even when its mixed with anti freeze, use distilled water, one gallon distilled water to one gallon antifreeze. if you mix it make sure its not the kind thats already pre mixed. and mix it before putting it into the radiator
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
#17
Re: overheating
actually durring the summer i run a 70/30 water/antifreeze mix. water has far better heat transfer properties and therefore can absorb more heat. durring the winter i switch back to a 50/50 mix.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
#18
Re: overheating
i thought it was the other way around. somewhere I read that you shouldn't use distilled water.i thought it was a little odd to recommend against water that is more pure. i don't know if the author was confused (it was from a reputable company, like chevyhiperformance or something) or what.
Anyway... i've never bothered with it, I just use the stuff from the water hose.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
