Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 07-21-2001, 11:51 PM
Koojo's Avatar
Koojo Koojo is offline
Send a message via AIM to Koojo
stock is 15
Old 07-22-2001, 12:30 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Originally posted by Koojo
Seems like 19 can cause some damage, and I dont want to take do something that Im not sure about.
I don't know where you get this impression but if you run premium gas you won't have a problem. If you can't, or don't want to, afford premium gas then don't set your timing to 19 BTCD; keep it at the stock setting.
Old 07-22-2001, 08:14 AM
geoff200 geoff200 is offline
I don't have a problem about running good grade fuel, in fact I am forced to put 95 or higher in. I guess I could set the timing to 19 degrees without worries then. What would this do to the torque curve? would I loose some low down power in exchange for more power at higher rpm or visa versa, or more power all round? How do you set the timing - do you turn the distributor like on cruder cars? or is this an ECU remapping thing?
Old 07-22-2001, 08:54 AM
G-Forces's Avatar
Banned
The only thing advanced timing costs you is the extra money for the premium gas.
As to the procedure go to www.se-r.net and look for it on there. You have to do some raindance ritual that involves revving the engine 3 times to 4000rpm then holding the revs are ~2000rpm for 1 minute or so, disconnecting the tps, blah, blah...check out se-r.net for the actual details. Oh BTW you need a dialback timing light too.
Old 07-22-2001, 01:22 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
I think every motor is going to act a little different when the timing is advanced, but I don't think you will lose power anywhere, unless you were to possibly overadvance the timing, then you may lose power???
With 19* timing my dyno didn't lose power anywhere, the dyno was almost identical to the prior run except from about 4500rpms on up to about 7000 rpms. It looked like someone just pulled the line up for that 2500rpm range and left the rest of the graph the same. However, your motor may react different, so I'm not totally sure how it'll react.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 07-31-2001, 09:28 PM
P11GT's Avatar
P11GT P11GT is offline
Send a message via AIM to P11GT Send a message via Yahoo to P11GT
SR20 timing
ive checked out se-r.net but cant seem to find any info on the proceedure for setting the timing 17 or 19 degrees BTDC, can anyone post a link to the specific page? Thanks
Old 07-31-2001, 11:04 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
http://www.se-r.net/engine/about_timing.html
Old 08-01-2001, 01:21 AM
Dshaft96 Dshaft96 is offline
I've got my timing advanced to 19*. I run 92 octane gas no problems. Throttle response is an enormous improvement. When I first checked my timing it was at 13*. It's really easy; just get a dialback timing light and follow the se-r.net procedure. Oh and all the Sunocos around here (Toledo, OH) sell 94 octane for about $.10 more than 92.
Old 08-01-2001, 07:08 AM
b-b00gie's Avatar
Banned
Yep, I think the Nissan slave workers / robots set the timing trivially to somewhere around 13 to 15. Seems there is no consistancy lol...
Old 08-01-2001, 02:33 PM
Do you think 19 is better than 17. The Se-r.net link says 17. Also have any of you tried it on a European Primera which I have been told has slightly higher compression than US G20's.
Old 08-01-2001, 02:40 PM
b-b00gie's Avatar
Banned
not sure about the compression issue.
Many people have done 19* safely. I have mine at 17*
One thing Geoff, I've heard that US octane levels are not measure the same way as other countries.
Your octane may be + or - what ours is...
For example.. if someone in the US says they run 19* advanced with 92 octane, in the UK you may need 95 octane, or maybe only 89 etc...
Not sure which way it varies, but I have heard this several times.
Old 08-03-2001, 07:16 AM
Anthony Anthony is offline
Lightbulb Timing on euro spec SR20 motors
Nissan specify that the timing on a Euro spec SR20DE should be 15 +/- 2 degrees. You should be able to set the timing to 17 degrees using standard 95RON petrol, but I'd be wary of going higher than that unless you use 98RON petrol. Even with 98RON, I wouldn't go above 19 degrees if you value your engine, as the higher compression of Euro spec SR20 motors (10:1 vs 9.5:1) means you won't be able to safely increase the timing as much.
Remember - if you set the timing too high the engine will begin to "pink" under load. The SR20 series engine's have a built in knock sensor, so the ECU will "hear" this pinking and pull the timing right back. Therefore you are likely to get WORSE performance than if you'd left the timing at 17 degrees.
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 08-05-2001, 08:11 PM
Thanks for the advice - it's 17 degrees for me then.
If anyone has experience of a JWT chip on a european G20 please post, because I know some of you are fitting these instead of advancing your ignition. The JWT chip must advance extra through its mapping.
Old 08-05-2001, 08:27 PM
G-Forces's Avatar
Banned
Please everyone, I might be splitting hairs here but JWT sells ECUs. You cannot get a chip for any G20. Unless you have a modified ECU that takes chips.
Old 08-05-2001, 10:02 PM
P10DET's Avatar
P10DET P10DET is offline
Originally posted by DVSNCYNIKL
Actually, you guys do have better gas than we do.
No. We do use a different scale from the rest of the world. Their octane rating is Research Octane Number. Ours is an average of RON and MON (Motor Octane Number).
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
SHOW YOUR WHEELS ON YOUR 07 TAHOE! 22's, 24's, WHAT YOU GOT? biglg Tahoe 0 09-26-2006 06:35 PM
Whats the fastest you've got your Z up to? Broke_as_**** Off Topic 4 09-18-2006 12:55 PM
How long after you got your car did you replace the radio? with what? razo164 Lancer 1 08-09-2002 07:20 AM
Let's see what you got!!! importboy '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 03-01-2002 04:57 PM
