Old 06-30-2005, 02:30 PM
White Lightening's Avatar
White Lightening White Lightening is offline
Re: Re: Re: Locking Differential versus Limited Slip differential
Originally Posted by twomorestrokes
When I ran my VIN on GM VIS it came up as G80 / Locking Differential- Rear Axle.
My guess is that GM's version is just another name for limited slip, not a true locker.
My 2004 Silverado has a RPO code of G80.
Directly from the RPO Codes guide is the following:
"G80 Differential, locking, heavy-duty, rear
G86 Differential, limited slip, heavy-duty, rear"
. . .>>>>> . .White Lightening . .<<<<<
More pictures???
Link below shows them & a list of features and options on this 2wd SS
V.H.O.
http://files.automotiveforums.com/ga...ite+Lightening
Old 06-30-2005, 02:37 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Get the RPO Detail print out from the dealer to verify exactly what you have. Some codes were different to models in the same year.
Also you can get the mechanics in the dealers shop to tell you what the difference is, they have torn down a few I bet.
Old 07-01-2005, 08:09 AM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Originally Posted by Moose is loose
No clutches on a true "locker". They use metal teeth that mesh together--locked. The only way they can slip is when the teeth basically skip a cog (causing the BANG!). This should help:
http://www.powertrax.com/nsexploded.html
Right. These G80's must be basically just a limited slip simply named "locker" by GM. Correct?
Old 07-01-2005, 02:47 PM
From my understanding - the G86 is the limited slip version (not positration but limited slip) - while the G80 (positraction) is the type used in the SS and in my v.h.o. 2wd truck. My understanding (from others) is that positration is a better traction method than is limited slip - and is often used in heavier duty or higher powered vehicles).
Old 07-01-2005, 03:03 PM
Re: Re: Re: Re: Locking Differential versus Limited Slip differential
Positraction and Limited Slip are two names for the same thing. The G80 locker also uses clutches, but a flyweight and cam setup to operate the clutches. Check this link, complete with video.
http://www.traction.eaton.com/prod2.htm
Old 07-01-2005, 03:11 PM
Re: Re: Re: Re: Re: Locking Differential versus Limited Slip differential
I also did a search engine of "G80 locking differential" and found forums where complaints of the Eaton locker (G80) was chattering on turns when hot. The fix (according to GM, according to this forum) was to replace the diff fluid with synthetic, but DO NOT add the friction modifier additive to this G80 setup. If so, it should be flushed, as the discs are metal and the additive can cause them to glaze over.
Apparently GM's locker and limited slip are two different types of differentials.
Old 07-01-2005, 03:17 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
I think if more people new of and understood the benefits of LSD's and locking diffs, there would be a lot fewer 4wd vehicles on the road.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-01-2005, 04:59 PM
redneck45 redneck45 is offline
you got me thinkin now, my duramax G80 I put mobil 1 syn in and it acted fine as well as the G80 in my '99 1/2 ton, but my '97 formula firebird when I put just the mobil 1 in made a hellava racket until I put in a bottle of the "limited slip lube"! Def. two different types of rears!
Old 07-01-2005, 07:12 PM
05SilvyHP 05SilvyHP is offline
The locking diff in the chevy rear on my truck is a limited slip posi. If it were a locker, like everyone has said, if would be way annoying when turning. The limited slip allows for just that--limited slip of each of the rear wheels. A locker or spool is terrible on turns, especially tight parking lot manuevers. It allows for no slip, which is great for drag racing or off-road traction, but sucks in everyday driving.
later
05 Silverado HP edition. 2wd 6.0 ext cab short bed. Black. STS turbo ordered.
Old 07-01-2005, 07:44 PM
Moose is loose Moose is loose is offline
I had a 1970 Chevy C-10 with a Posi rear. If I didn't use the GM addative, it sounded like I had timing gears at any speed above 40. Sounded kinda cool, but after having to replace the rear, it wasn't so cool. I was also 16 back then. Just be sure to use the $$$$ bottle of addative from GM, it will save ya.
Old 07-01-2005, 07:47 PM
later
Read the page, it is a locker; Eaton has a seperate pager for their posi/LSD setup.
Old 07-03-2005, 01:39 PM
spudglo08 spudglo08 is offline
Send a message via AIM to spudglo08
For Clutch-Type Limited Slip
Go to http://auto.howstuffworks.com/differential8.htm
For Locking and Torsen® diffs
go to http://auto.howstuffworks.com/differential10.htm
Old 07-03-2005, 01:46 PM
GM doesnt use a "true" locker cus it only engages if the drive weel slips.To demonstrate find some dirt and do a burn out but slowly give it gas and listen after about 1-2 revolutions of the drive tire "left weel" you will here a ping sond and the right tire will start to spin if you have a locker if not the left will just keep spinning.
Old 07-03-2005, 01:54 PM
The Torsen differential* is a purely mechanical device; it has no electronics, clutches or viscous fluids
The Torsen (from Torque Sensing) works as an open differential when the amount of torque going to each wheel is equal. As soon as one wheel starts to lose traction, the difference in torque causes the gears in the Torsen differential to bind together. The design of the gears in the differential determines the torque bias ratio. For instance, if a particular Torsen differential is designed with a 5:1 bias ratio, it is capable of applying up to five times more torque to the wheel that has good traction.
These devices are often used in high-performance all-wheel-drive vehicles. Like the viscous coupling, they are often used to transfer power between the front and rear wheels. In this application, the Torsen is superior to the viscous coupling because it transfers torque to the stable wheels before the actual slipping occurs.
However, if one set of wheels loses traction completely, the Torsen differential will be unable to supply any torque to the other set of wheels. The bias ratio determines how much torque can be transferred, and five times zero is zero.
This is what GM uses in the trucks
Old 07-03-2005, 02:00 PM
That is how AUTO 4X4 works also
The silverado SS has Viscous Coupling http://auto.howstuffworks.com/differential9.htm
