#16
Re: Can't always get key out
you said "in conjunction with a slipping tranny ..."
... can you feel the tranny slipping or are you just getting the codes with no other signs of tranny problems ? have you ever changed the fluid and filter in your tranny? Quote:
#18
When the codes are set, the tranny goes in to limp mode. Limp mode locks it in to 3rd. Taking off in 3rd makes it seem as though the tranny is slipping, but it isn't.
http://www.automotiveforums.com/vbul...d.php?t=425697 |
#19
Re: Re: Can't always get key out
Thanks blazee! I will look into this. It doesn't look like a recall though. This definatley seems more of what it is doing instead of slipping. I will have to pay more attention to it the next time I drive it (it's the wifes car actually). It moslty resembles driving while pulling a big boat up a hill. I feel the trans slipping, but it is most likley the torqu converter compensation for driving around in third gear. To answere the other questions, I did do a tranny fluid change. It was nice a red at the time I did it, so I didn't bother with the filter change and flush. |
#20
Thanks for the info and there is another great post on too. I have not had it shut off on me, but I just had to replace the alternator. Probably not related. |
#21
As far as the starting off in 3rd gear and engine light without a doubt ignition switch will fix this the white wire from the switch is not supplying the transmission with a necessary voltage.
#22
Re: Re: Re: Can't always get key out
I wish I would have tied this method (cleaning) first!!!! I probably should have, but it's my wifes car and she elected to replace the part. It is a real pain in the neck (legs, hands, and lower back) to replace. Have to remove the entire dash underneath and no garantee that you will not break parts. The lock tumbler must also be removed and some special tools (reverse torx drivers) are needed. Took about 5 hours to do, at least 3 of those were running around trying to figure out how to remove the tumbler and looking for tools.
However, so far, so good. |
#24
i got the same problem with my 03 blazer. the key will not return and stays in the ignition but if you let it sit for 5-10 min. it usually comes out with no hassle but very annoying. any suggestions??
