#16
Re: Intermittment whining sound
there were no problems, ecept my dad said it took like $1 more in gas.
#19
I had this problem for a year.
I took the vacuum line around fuel rail ( ablove PCV valve) off yesterday as victimizati0n said and now the whinning noise went away. Thanks victimizati0n. But I don't know what to do with the both open end of the line yet. Any ideas? |
#20
Re: Re: Intermittment whining sound
I wouldnt drive around with the vacuum hose off. It was put there for a reason, if you know what i mean. I can say that we do drive around with the hose off, and we have had no problems, but it might be a different situation. I would go back to the dealer, and tell them what is going on, and show them that when you unplug the vacuum, the noise goes away, they might then be able to diagnose that it is your fuel pump that is the problem. |
#21
Re: Re: Re: Intermittment whining sound
What are you guys taking the vacuum line off of. the fuel pressure regulator, i tried that and it didn't change the way the motor ran...I unplug a few other sensors and it didn't affect the idle of the motor, expect a few times it started to misfire like it usually does. I took the sensor thats closest to the air box off...no change....i took the vac line of the fuel pressure regulator off..no change....and the sensor after the one closest to the airbox/air cleaner off. and no change....so many fricking sensors it's ridiculous!!!
So what vac line are you taking off? Mike |
#23
my car still whines with the vac line off so i don't know what it is,only in overdrive though
