Old 12-22-2005, 11:12 AM
chris13174 chris13174 is offline
Send a message via AIM to chris13174 Send a message via Yahoo to chris13174
Amazingly enough, I have had the same exact problem on my 93 lumina and I have tried everything under the sun to fix it. Replaced coil packs, ignition control module, Idle Air Control, MAP sensor, crankshaft position sensor, and have did the idle relearn thing and still the car does not idle clean. My lumina is the 93 3.1L Vin T Engine. I moved onto checking the vacum hoses and did find several vacum leaks but I have now fixed them. According to the chilton books I have on the car, the 3.1 is very sensitive to vacum leaks and repairing the leaks on mine did clean up the idle substantially for a few days, it is now back to the same rough idle and stalling that it originally started doing. What might be the problem here? Would it be worth $24.95 to pay AllData.com in order to see if maybe they have something listed on this problem which seems to be overwhelmingly common amoung these cars?
Old 12-01-2020, 03:00 PM
Lolamonster Lolamonster is offline
Re: 91 Lumina - how to check codes?
I have a 1991 Chevy Lumina Apv.
8th letter/number of Vin is a D.
I got a CODE:15 from the OBD1
Could you please tell me what it means?
Thank you
Old 12-01-2020, 03:42 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
15 Coolant Temperature Sensor (Low Temp Indicated)
Old 12-02-2020, 03:28 AM
Schurkey Schurkey is offline
Thank you
https://repairpal.com/gm-obd-code-15
You need to TEST the system before replacing parts. This could just as easily be a wire-harness problem as a sensor problem; or even a failed computer.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
The Following User Says Thank You to Schurkey For This Useful Post:
90serawhips (02-28-2024)
