Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 06-14-2005, 11:33 PM   #16
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: lumina apv has no spark
Generally timing won't make them run rough, just weak if retarded or hot and pinging if over-advanced. I'd be leaning more to vacuum problem, if it seems to run OK off idle.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 06-15-2005, 01:08 PM   #17
70blue
I am glad it's running but one quick word of advice. I had an intermittent fuel and fire problem with my 92. I replaced the module. Went one hundred miles round trip no problem. Later that day pulled out of my drive it died.
Pickup coil was bad too. If you have any more problems the pickup coil will cost you about 13 bucks at autozone and be the most likely culprit.
70blue is offline   Reply With Quote
Old 06-15-2005, 03:06 PM   #18
EZFrank
once she starts up she runs for a bit but very rough and if you keep your foot on gas pedal she wont shut off but just very rough feels like maybe shes not running on all cylinders or just a vacuum issue.
[IMG]http://[/IMG]
EZFrank is offline   Reply With Quote
Old 06-15-2005, 09:40 PM   #19
EZFrank
Well guys found the problem 1 of the vacuum hoses had a pin hole and 1 of the fuel injectors aint spraying it was clogged but its finally fixed and running great. Would like to thank you all especially jeffcoslacker for all the help, you guys are all great. FrankC
[IMG]http://[/IMG]
