Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-23-2005, 01:58 AM
InstallTech's Avatar
InstallTech InstallTech is offline
Re: 93 Camry LE idle/fuel (?) problems.....
Well....there seems to be an aparant victory in this battle of the bad idle. Did some calling around, and one mechanic suggested the internal ignition coil inside the distributor. So far....this has done the trick. Just posting this so that others in the future that may have this same problem will know what to possibly look for. Don't worry....if it turns out to not work after a week or so, I'll be back. :P
I reject your reality, and substitute it with my own.
Old 06-23-2005, 09:44 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Thank you for the update
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-13-2005, 06:23 PM
Bmaintz Bmaintz is offline
OK, I will try to help you.... I have a '92 & '94 Camry with the 2.2 engines.... My '92 blew off the lower hose & got real hot (my Amsoil saved the engine)... Camry would not start after cooling down so had towed to house.... I was going crazy as you are.... There is a Condensor (capicator) on one side of the ign. coil INSIDE of the distributor that can LEAK or SHORT out.... If it shorts out it will take a fuse out.... If it has leakage it can drop your ign. voltage..... This condensor can be bought at you Toyota dealership but they will probably have to order it (around $2.50)..... My condensor shorted due to the engine getting hot (dead short)..... Hope this helps....
Bob
South Mississippi
92 & 94 Camrys
Old 07-13-2005, 11:49 PM
Thanks for the info. I ended up fixing it a few weeks ago. It wound up being the ignition coil in the distributor. Haven't had a problem since. Thanks, though.
Old 07-14-2005, 08:02 AM
Did you replace the Condensor??... Might be a good idea as they will fail or leak because of the heat over time.... Where did you get your Ign. Coil & Price? $____ ... Bob
Bob
South Mississippi
92 & 94 Camrys
Old 07-14-2005, 10:08 AM
I got the ignition coil at my local O'Reily's auto parts store. Cost about $40.
