Old 06-09-2005, 01:46 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Please Help. Stalled And Wont Start!
shot fuel pump most likely
Old 06-10-2005, 03:29 PM
pegasus81 pegasus81 is offline
Smile
I Have A 1995 Blazer, And It Had The Same Problem We Tooke Off The Egr Valve Cleaned It Applied A New Gasket And The Put The Egr Valve Back On And It Started Right Up. Try That And It Only Cost $1.00 For Some Carberator Cleaner.
Old 06-10-2005, 03:32 PM
Thumbs up Re: Re: Please Help. Stalled And Wont Start!
My Blazer Did The Same Thing. Clean The Egr Valve With Some Carb Cleaner And Apply A New Gasket And Put The Egr Valve Back On And It Should Start Right Up.
Old 06-10-2005, 08:27 PM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Sounds like bad fuel pressure. You need at least 60lbs on that system. Repace fuel pump.
Old 06-10-2005, 08:30 PM
SlowRider22 SlowRider22 is offline
I took the EGR out and soaked it in gas for a few hours. Replaced the gasket but still no go..I am going to change the fuel pump tommarow. And put a new filter on to. If that is not it then I dont know the whole fuel system will be new.
Old 06-10-2005, 08:48 PM
If the fuel pump deosn't fix the problem try checking the O2 sensor in the catalytic converter since they are together if with milage and age if the catalytic converter is clogging the O2 sensor with send faulty info and that may also be keeping the truck from starting, the back built up pressure keeping the motor from mixing properly. just another connected idea. good luck.
Old 06-11-2005, 01:37 PM
Fractured1 Fractured1 is offline
have you checked the fuses for the ecm ect.
Old 06-11-2005, 09:34 PM
Okay she is FIXED and running. Although I did learn a 450 dollar lesson. After I got it fixed like 2 minutes later the starter pooped the bed. But the lesson was 320 dollars dor a fuel spider. And 100 dollars for a new starter due to trying to start it to much. So I spent 450. The only thing that was wrong was when I pulled the pump out of the tank it was like new. No pressure though so we took it out. There was a hole in the little rubber hose that is about 2 inches long that connects the pump to the hopusing thing. So all I needed to really spend was about 30 cents not 450 dollars. Lesson learned dont jump to concluisions..
FUEL SPIDER 320 BUCKS
FUEL FILTER 8 BUCKS
STARTER 100 BUCKS
LEARNING ALL YOU REALLY NEEDED WAS PATIENCE AND A 30 CENT HOSE......PRICELESS
There are some things money cant buy for everything else there is Autozone..
Old 06-12-2005, 07:07 AM
blazee's Avatar
blazee blazee is offline
Problem?
If you replaced that with a cheap piece of hose....you can expect more problems in the near future. A cheap hose can't hold up to the pressure.
Old 06-12-2005, 07:18 AM
I used fuel injection hose
