Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-07-2005, 12:01 PM   #16
clipsekid99
clipsekid99's Avatar
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Buschur Racing makes a nice alcohol injection system. It's featured in the June issue of Turbo magazine where they tested it on an evo. The evo make 443 on the dyno @ 23psi on 93 octane pump gas with the alcohol injection.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
clipsekid99 is offline   Reply With Quote
Old 06-07-2005, 11:51 PM   #17
joemathews
joemathews's Avatar
Re: FedEx dropped this off today..
WOW. Surely that evo was not on the stock turbo...
1996 Eagle Talon
joemathews is offline   Reply With Quote
Old 06-08-2005, 04:29 PM   #18
kjewer1
AF - Advisor
A local stock turbo evo made similar power numbers. And he's not alone. The EVO's turbo with the 10.5 cm exhaust housing has a lot of potential with minimal mods. The local guy mentioned had a MBC, exhaust, intake, and cams.
But then again, I dont think he did that on pump gas. I think the pump numbers might have been 400 even. Of course the whole point of alky injection is to duplicate race gas performance on pump gas fuel, so none if this really matters anyway. The race gas number still applies IMO.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
kjewer1 is offline   Reply With Quote
Old 06-08-2005, 10:03 PM   #19
joemathews
joemathews's Avatar
I'm still very impressed, though. I was under the impression there wasn't a lot of difference between the Evo8 16g and the EvoIII 16g, but apparently I was wrong! 400hp on pump is sick for a 16g.
1996 Eagle Talon
Old 06-09-2005, 01:10 AM   #20
kjewer1
AF - Advisor
Flow numbers end up being pretty equal. But the much larger exhaust housing increases VE, and the twin scroll housing/paired cylinder manifold keep lag down despite its size. I guess.
Kevin Jewer
Old 06-27-2005, 09:16 PM   #21
guitarXgeek
guitarXgeek's Avatar
Send a message via AIM to guitarXgeek
*** UPDATE! ***
Alright guys, the intercooler has FINALLY been mounted. We didn't have time to do the piping yet, but that is being done this friday. Here are some pictures of it mounted on the car...
Like I said, piping and stuff is getting done this friday! I'll be sure to check back with some more pics, as well as a review of the intercooler's performance
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
guitarXgeek is offline   Reply With Quote
Old 06-27-2005, 11:08 PM   #22
Killa_DSM
Killa_DSM's Avatar
Looks really good!!! Much better then before, your going to short route the piping right?
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Killa_DSM is offline   Reply With Quote
Old 06-27-2005, 11:37 PM   #23
97_3clipse
97_3clipse's Avatar
Send a message via AIM to 97_3clipse
no fog lights!(weight reduction) Front mount intercooler, no pipes(looks fast but isnt) .....you ricer lol
well atleast now it looks kinda cool
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
97_3clipse is offline   Reply With Quote
Old 06-27-2005, 11:51 PM   #24
guitarXgeek
Re: Re: FedEx dropped this off today..
Thanks! And yes I'm going with short-route piping.
Yea, you can't tell the pipes aren't there from far away . Either way, I am still a ricer for sure
I also just purchased a plx m-250 wideband o2 that should be here sometime this week. I may just go ahead and have Victor weld in an o2 bung for me and I'll wire up the wideband into dsmlink this weekend, too
95 GSX
Old 06-29-2005, 07:44 AM   #25
kjewer1
AF - Advisor
MAke sure you cap off the inlet and outlet before you drive, if you haven't thought of this already. It would suck to have a rock get in there, then go through the motor when you finally get it plumbed in
Kevin Jewer
Old 06-29-2005, 03:22 PM   #26
guitarXgeek
Damn, good idea. We have to take the intercooler back off anyways (only 3 bolts) when we do the piping so we're just going to clean it out then. Thanks for the concern though
95 GSX
