Old 05-27-2005, 08:06 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Switching to Synthetic..bad?
ditto
also...if u have a JDM ZC then have 30k miles on the engine is about right...i'll elaborate more...mabey later
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-27-2005, 11:56 AM
Juicy05 Juicy05 is offline
mine is a 91 and has 35k on it.....
Old 08-06-2006, 08:43 PM
silvrcvik silvrcvik is offline
Thumbs up Re: Switching to Synthetic..bad?
Planning to switch my car over to synthetic tomorrow....
99 Civic Ex -- crankshaft and motor was replaced roughly 35k ago
been running plain 5w30 since 40k when i got it.
I have been reading up and is it BS that you cant switch back...
I am assuming that i dont need to add anything in order to switch?
but should i be using partial syn. for my first switch???
also....should i make another switch after 1-2k miles???
these are just some ideas ive read........
oh yeah and i saw that lucas oil stabilizer in the store....
whats up with it....is it for leaks or something?
Old 08-06-2006, 08:56 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Make the switch, you can go ahead and use partial or full synthetic oil in your car... use either 5w30 or 5w20. Once you pick what oil you want to use...be it synthetic or dino, STICK WITH IT. Oh and i woudn't pour any oil treatment into my crankcase...even Lucas. Oil treatments are all BS. So dont add anything when switching.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 08-06-2006, 10:04 PM
viper-blue's Avatar
viper-blue viper-blue is offline
this is just my opinion but if anything you should expect not to burn oil switching to syn oil....my rex has 250k and still runs strong....it burns regular oil and I do pound the hell outta her, but put some good synthetic in her and the oil lasts twice as long...no leaks either...
Old 08-07-2006, 11:01 AM
BLU CIVIC's Avatar
調整器
if your car is burning oil or leaking oil the something's wrong with your engine...to say it won't leak or burn oil sounds like a myth
The name's Adrian
2011 CR-Z - Stock
Old 08-07-2006, 08:08 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
You dont need to switch anything else over when you switch to synthetic. My dad was in the oil business for a long time, and talked to a rep for Castrol and the rep even told him that you can get close to the same protection from running like 4 quarts of convential with 1 quart of synthetic, as you would if you ran full synthetic. Now how true it is, I don't know, I usually run full synthetic and still change every 3000 miles. I like using the synthetic because of the higher protection and the extra miles if I need it. If your planning on running it for its full life, of 7k or more, you need to switch filters. Most filters are only good for 3k miles and thats it. You could always just change the filter too if you wanted to, but I would just change it all.
As for Lucas, Lucas is one of the few additives that isn't BS. I swear by Lucas, especially their tranny additive, which might take an hour to pour in, but well worth it. I have known a tranny to loose all gears but like first and reverse, put a thing of lucas in it and get the gears back.
Just my 2 cents on it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-07-2006, 09:07 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
My tranny has a bad 3rd syncro and a crack in the bottom that slowly drips, im willing to throw some of that crap in there for the sake of knowledge..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-08-2006, 12:18 AM
Tony's Avatar
TLD Member #1
Its good stuff, I mean its not better than actually fixing the problem, but it can usually get you by, just be prepared to wait 30 mins for the bottle to empty, its some thick stuff.
Tony
Old 08-08-2006, 12:20 AM
FrodoGT's Avatar
Yeah ive put some similar stuff in with the oil on an 800hp diesel in a boat, full jug of it..took forever!
Current project:
Rio Red 91 hatch.
Old 08-08-2006, 08:10 PM
arodg25's Avatar
arodg25 arodg25 is offline
all these japanese engine claim low milage, and most are true but you have to understand that japan is extremely over populated and traffic sucks so the engine you buy probably has the same amount of hours on it as one from north america, they just didnt go as far.
Old 08-12-2006, 10:40 AM
sblkcamaro70 sblkcamaro70 is offline
Originally Posted by 91CRXTC
OK so that does sound false and i would think that a motor that supossedly had maybe 40-50k on it when i got it wouldnt burn a quart of oil a month so i am sketchy about the age of the motor, besides how can a motor from 89-90 only have 40-50k on it. Does anyone have any idea what i can do to burn less oil besides drain the oil out. LOL
just cus it only had 40-50 k on it doesn't mean it is a good motor. the rings over time get weak even when they just sit there. my 89' dx with 130,000 on it burned a quart of oil every 200-250 miles. it also has to do with the previous owner too. i know who ever owned my car before me rapped it hard.
Old 08-12-2006, 10:52 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
The reason older motors offen develop leaks and start burning oil after switching to syntheic is because the synthetic cleans the inside of the engine, removing all of the varnish and deposits that are plugging all the holes. I believe this is the study that was refenced earlier about oil filters, http://minimopar.knizefamily.net/oilfilterstudy.html .
