Old 05-27-2005, 12:37 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: Re: trubo swap
Originally Posted by sganc4life_4
Dejon tool makes a LICP that goes straight from the turbo to the stock intercooler, its the pipes i have
Oh ok I get it, but you really dont need the whole LICP for the 14b to work. It would be better, but if your on a bugit just get the short j-pipe. It works the same.
But if you have the money it would probably be better to get the whole LICP, I blew my intercooler pipe off while I was racing and thought I blew the engine!
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: trubo swap
This install is easy. 4 bolts on the manifold, 3 bolts on the downpipe. Disconnect 2 oil lines at the filter housing and pan. Disconnect 2 water lines. A few bolts for heat shields... one o2 socket for the sensor.
Note, not in that order It's 100% simple, but how EASY it is depends on your mechanical skills and if your bolts are stubborn. Gaskets are somewhat reusable, but if you hate the wrench time, you might hate having to fix a leak later. Manifold-turbo gasket, turbo-o2 housing gasket, o2-downpipe gasket, crush washers are reusable, oil return gasket... did I miss anything?
Old 05-27-2005, 12:45 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: trubo swap
Not that I can think of, water lines are reusable also
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
