#16
Re: Whats under your hood?!?!
alright here it goes
1988 civic dx hb d15b2 cheapie ebay intake w/k&n filter dc sports header 2 1/2 inch straight pipe 2 1/2 inch full catback exhaust 8mm accel spark plug wires ngk plugs drop zone coilovers tokio adjustable gas shocks 1/4 mile time unknown guessing slow |
#17
nothing special here
jdm b16a LS trans exedy 9.5lb flywheel exedy stage 1 clutch K&N filter in stock, chopped up airbox like i said nothing special, need more money for mods.
Saturn Stealership Technician #331 |
#18
Re: Re: Re: Whats under your hood?!?!
2008 KIA Spectra5 SX 2010 Honda CR-V EX |
#19
yea i say get the new stuff new axle and new bearings..... safety issue
#20
What the hell, here's my setup:
JDM B16A HCP mounts 92 GSR tranny shitkara header (about to replace w/DC) Custom exhaust w/ Magnaflow resonator, Catco Hi-flo cat, spp muffler home made CAI w/ monsterflow foam filter full ES poly bushings no name strut bars (free) Powerslot rotors w/ aem pads 91 teg M/C, booster, prop valve, rear disc swap w/Powerslot rotors (not installed yet) and steel braided lines Tokiko Illuminas H&R sports Konig Next w/ Falken zx512's Si seats front and rear CRX dash swap Skunk2 short shifter Optima yellow top (relocated to "trunk") Power mirrors That's about everything, except the stereo stuff, and the B18A1 block in the garage. |
#21
89 si:
![]() '00 Ex y8 Center Force Stage2 dual friction clutch 100% real Carbon fiber intake DC Sports Header DC Sports Strut bar 91 si: installed engine set-up in this car and ran it for a year. just recently pulled it out and replaced with stock a6, sold the car to brother-in-law. ![]() current set-up is now in yellow 91 si, no pics yet. b16a LSD tranny HASport mounts HASport linkage Skunk2 intake mani AEM CAI w00t! for Honda power
"hi! my name is Lady, and i'm a HONDA-holic" ..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose! ![]() *~ I <3 the G Ride ~*~ I <3 OLD SKooL |
#22
Uh oh here comes the ever powerful FODO listing:
Stock D15b2 Ebay 2 piece CAI with Spectre filter (may be changed out soon) 3A Racing rear section exhaust (will be changed out for better full exhaust) TEIN S Tech Lowering Springs T25 turbo and OBD1 mpfi intake manifold sitting in room and may or may never be installed.
1991 Honda Civic DX Sedan |
#23
![]() Weight reduction. J/K The motor is at millinieum autosports now. compleatly rebuilt B16, 9.5 to 1 compression getting ready for turbo.
Right now...
JDM B16a, PR3 ECU, Apexi VAFC, Hybrid S1/A1 LSD tranny but going in in a month or so B17a Block (bored .20 over) B16 Crank Wiseco 10.75:1 CR Pistons and XX rings Eagle H beam Rods GSR Oil Pump Fully balanced Lightweight underdrive pulley Exedy 9.5lbs Flywheel 6puck Sprung clutch All King Bearings ARP bolts OBX Oil pan Ported and Polished B16A2 (99si) head Skunk 2 Stage 2 Cams Fidanza Cam gears Rev High Lift Springs Rev Titanium retainors Rev Stainless Steel valves All new Gaskets and seals Ported Intake manifold High Flow fuel Rail Fuel Pressure regulator Wicked 4-2-1 stainless Header 100 shot NOS Direct Port Nitrous then that will be mated to my custom S1/A1 LSD tranny.
2012 VW Golf 3 Door Automatic (Company Car) 2011 VW Golf Wagon 5 speed (Company Car) 2010 VW Jetta 2.5 Automatic (Company Car) 2009 VW City Jetta 5 Speed (Company Car) 2009 VW GLI 6 Speed (Company Car) 2008 VW Jetta 2.0T 6speed (Company Car) 1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold 1990 CRX Si (Built B17a) - Stripped and Crushed 1988 CRX Si -- Stolen 1990 Civic Cx -- Sold 1990 Civic Si -- Parted 1989 Civic dx -- Sold |
#25
89 civic hatchback will post pics soon
93 b18a1 block with a b18b1 head obx-r cam gears fuel pressure regulator 4-2-1 header act stage 3 clutch 9.3mm spark plug wires and thats about it fastest time ran inna 8th 9.1 on slicks. next month some time I'll be doin LS/Vtec usin a b16 head. |
#26
I have a 90 hatch si with a b16a1 swap, DC headers, Apex'i Exhaust, STR cam gears, Type-R Clutch, CAI, MSD ignition wires and NGK plugs. Not that great but I guess it's ok
#27
I drive a slow car. |
#28
![]() Im actually in the process of swapping in this: ![]() ![]() Cant wait till its finally in! |
#29
OK my turn...
Under the hood: 91 dx crx chassis i think 90 DOHC ZC Stage 2 cams 90 SI tranny Integra LS ECU SI wirharness Iceman Intake w/K&N MSD Ignition w/ external coil and wires NGK plugs that are one stage colder then stock HP Power Header Custom 2.25 exhaust w/ a V8 muffler Mobile 10w40 with fram Super guard filter Not under the hood: Neuspeed springs Tokiko Adjustibles D/S front Brembo rotors D/S rear brembo rotors 90 teg. rear disk conversion Magnum S.S. Brake lines F&R upper & lower rear strut bars upper front strut bar OZ Racing F-1 rims w/ toyo proxy's 195/50 16's Si seats and thats me in a nutshell....well, dx shell |
#30
Re: Re: Re: Re: Whats under your hood?!?!
check the torque of your passenger side axle nut. improper tq can cause bearing noise. Correcting it may fix it if damage was not already done. |
