Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-04-2005, 09:08 PM
stuzman stuzman is offline
Re: 88 2.9 runs really rich
Originally Posted by O.P
I tried the test with the jumper wire and ohm meter. I didnt get anything, so I am assuming that the test wires are bad going into the ECU. I will check them tonight. THanks, I will let you know what I find
OP
I assume that you had set it to measure volts instead of ohms. Just saw that you said ohm meter and not voltmeter. If it was set for volts, then it could be a bad PCM since you can't read any codes at all and possibly the reason for the rich condition.
Old 11-08-2005, 09:51 AM
bronconut bronconut is offline
Tested the TPS and it was 1.0 and 3.9 ohms. I bought a new one and got similar results 1.1 and 4.2. No dead spots. I relaced it anyway and still getting lots of black soot out the tailpipe. I think I am going to hit the return line and see what I can find.
Old 08-19-2018, 12:52 PM
rangerdangerxlt rangerdangerxlt is offline
i myself have a 1989 ford ranger xlt, it had a previous bad problem of shaking at idle which was caused by second and third cylinder ignition wires to be swapped around, so I changed those two to the proper way and it got rid of the shake, but now it is running rich and note that before with the bad shake it wasn't running rich at all. im not too sure if its just the motor running out all the old gunk and finally being able to fire in proper order but anything I should check out first ie. o2 sensor, stuck injector, I justr replaced the fuel filter when I pulled the old one the fuel came out orange which would be cause of rust so with that being said I assume some rust got the injectors and is causing to be stuck open, but I cant say for sure, any insight would be wonderful
