Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 10-18-2005, 03:11 PM
jcantu1982 jcantu1982 is offline
Send a message via AIM to jcantu1982
Re: 2000 ZX2 Engine Whining Sound
Tim, The whining sound on mine was miserable. The last thing I did is posted above dated...10-11-05. But am not sure I would recommend anyone to do it.
Let us know how it goes.
Old 10-19-2005, 03:29 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
at 6500 i sound like im supercharged
Old 10-20-2005, 09:21 AM
Timtickle Timtickle is offline
Re: Re: 2000 ZX2 Engine Whining Sound
How often are you 6500 rpm.
Old 10-20-2005, 01:45 PM
Banned
all the damn time
Old 10-21-2005, 07:33 PM
its a 2.0 engine its going to whin at 6500 rpm. its not a 5.0. enen when i bought mine brand new in 99 it was a loud running engine. There is really none to speak of when you talk sound proofing in the zx2.
Old 10-21-2005, 10:38 PM
Banned
yeah i know that, ive owned a ZX2 for over 4yrs. its the belts
Old 10-22-2005, 04:46 AM
Davescort97 Davescort97 is offline
Escort guy
[quote=Timtickle]Im not sure what brand my belt is but i changed my timming and serpentine belt in the same day and my car has been whinning since then. I have gotten used to it. Please post your fix
Tim[/QUOTE
On Escorts two different kinds of timing gears were used. Those with square teeth and those with round teeth. When replacing the timing belt it is IMPERATIVE to determine which kind you have. One kind of belt on the other kind of gear will whine. Sounds just like a supercharger. I found out the hard way. The wrong belt went 12,000 miles before it finally stripped out.
Old 10-24-2005, 09:19 AM
Great! In a good sence and a bad one. If i remember right i think the gear was square. Do the store carry both? They never asked me if i need one or the other.
Old 10-24-2005, 12:42 PM
Banned
Re: Re: Re: 2000 ZX2 Engine Whining Sound
all zx2's should have roundish teeth
Old 01-29-2008, 02:25 PM
Husky1986 Husky1986 is offline
My 99 zx2 whines also. I am pretty sure it is the serpentine belt. I have just replaced it, but not sure if it did it before since i just got it in a non-running state. I ran the engine without the serpentine and the whining noise went away. I wonder if one of my pulley bearings are bad. All the pulleys spun just fine before i put the belt on. I have heard that they whine sometimes without anything being wrong with them.
Can anyone help?
Old 01-29-2008, 03:11 PM
Re: 2000 ZX2 Engine Whining Sound - Fixed!
FINALLY FIXED THE WHINING SOUND!!!
As I said before I had replaced the pulley on the belt tensioner, that didn't work. 20K miles later, what happened is that the belt tensioner somehow locked up, causing belt to come off. So, I replaced the Belt Tensioner with one I bought from Advance Auto Parts. It really didn't have enough tension on it and caused rough acceleration and idling. I ordered one from Ford, replaced it, and it works great. NO WHINING SOUND, at last!!!! So, all this time it was that dead-gum belt tensioner!
I hope this helps out somebody, cause it drove me up the wall. Later!
Old 02-01-2008, 02:23 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
Live at 7300RPM..then tell me about whine. Most of the time it just the belts them selfs.
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 11-08-2008, 09:58 AM
riproaringca's Avatar
riproaringca riproaringca is offline
Hey all.
My '99 ZX2 needed a new belt a couple of weeks ago. Symptoms were a squeal when I first started up the car and until I accelerated. After about 5 seconds of acceleration it would go away, but return when stopped at a light or just parked and idling. And it was getting worse as the days passed.
Anyway, I did get a Gatorback belt from the parts store. Pretty aggressive belt, if you ask me but man-o-man it grips those pulleys!
I do notice a bit of a hum from the new belt, but it's better than the squeal from the old worn one!
When I installed the new one I found that the spring-loaded tensioner pulley/arm was seized after remaining in one position for so long. (I bought the car used so who knows when the belt was replaced last.) I worked it back and forth while installing the new belt just to get it moving freely again. Seems to have worked. (Pay attention to your grip on the wrench/socket - that tensioner arm is mighty strong. The spring will snap the tensioner back into place if given the chance, and there's little space to get your fingers out of the way!)
If you're going to replace the belt yourself, be sure to write down the pathway before taking the old one off. Again, there isn't a lot of space to get a good view of things along that side so having a "map" will come in handy when it comes time to put the new belt on. It's a lot easier with two people working on this job, too. (For those of us who aren't pro mechanics!) Another helpful tip is to get a Haynes or Chilton manual which describes this project. The diagram in the book saved a lot of time -- and minimized the swearing!
Same discovery here as other posters now that the new belt is on, and the tensioner has been corrected:
  • The car runs A LOT more smoothly.
  • The car idles more quietly.
  • The mileage has improved noticeably.
Hope this helps fellow ZX2'ers!
[email protected]
Peterborough, Ontario
1995 Escort LX 3DR - 1.9L, 4cyl. w/ OD
1997 Sable GS Wagon - 3.0L, 6cyl. w/OD
1997 Expedition XLT - 5.4L, 8cyl. 4x4 w/OD
1999 Escort ZX2 Coupe - 2.0L 4cyl. w/OD
1999 Taurus SHO - 3.4L 8cyl. w/OD
2002 F150 4x2 SuperCab XLT - 4.6L 8cyl w/OD
