Re: Re: thirdgen LS1 swap
Originally Posted by 89camaroperson
Are ls1 heads different than normal ones? is that why they are so expensive?
an ls1 is completely different from anyother small block chevy. absolutely nothing is interchangable between them. so the differences lie in much more than the heads...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
