#16
Re: Re: Re: Re: Re: Prestone Extended Life Coolant
Yes the red or orange is Dexcool, the Prestone Extended Life is green. I highly recommend the Prestone Extended Life. It works for me. Its in the OAT (organic acid technology) family which is what Dexcool is based on. Best part is if there is any residual Dexcool even on a good flush there is no harm when the two mix. Doesn't hurt aluminum radiators, engine components, or plastic. Its sold at all the national auto parts stores. Pep Boys, Autozone, Checker, etc. Good luck and let us know how it turns out. ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
#17
Reminds me I have to flush the water out of my system and replace it with mixed anti-freeze. I really hate the drain plug location on my GA, it's the likely reason why I conveniently forgot to replace the anti-freeze.
#18
'99 SE (l36) 125k mi. FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
#19
Glad to hear you got it done even with the bad weather. Maybe you can send some that that rain down here...lol. On the radiator drain plug I found the best tool to use is a 1/4 " drive ratchet or 1/4 " drive with a straight handle. It fits just right. ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
#20
i just put this prestone extended life coolant in my system the other day after i flushed out that shitty fuckin dexcool crap...must have been in there since car was new in 99, thats almost 6 years and i know all that sludge probably wasnt flushed out by water.....but anyway it works good keeps my engine nice and cool..i never knew you could keep the radiator cap above on jacks and you wouldnt need to bleed the system...maybe thats why i couldnt get any air out, makes me feel alot better knowing that now
#21
#22
