#16
Re: Re: Re: intake or nelson tune?
In my opinion the only reason GM usus TM is b/c they didnt want o upgrade their crappy tranny's and needed something to cover their butts.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
#17
Should my tranny go out, would I be able to put a 4L80e in its place?
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
#18
#21
Well, damn. The conversion parts cost almost as much as a tranny.
#22
Rookie Question.
How do I know if I have a 4l60E or a 4l80E Transmission. I have the 2004 Silverado Performance Package. White Lightening |
#24
1998 ECSB Z71
#25
Well, I'm sure the dealer could tell you
#26
1998 ECSB Z71
#27
With tranny' exact specifacations its hard to say, but this might help... 4.8/5.3/LS1 all use the 4l60e STOCK! LS6/6.0 use the 4l65e Stock, and the 6.0HD/8.1/Duramax use the 4l80e! And the 8.1/ Duramax use the Allison depending on if you requested it.
Yes you can fit the 4l80e in the truck and make it work. Depending on what you're long term goals are, it is hard to say exactly what we should recomend you do to your tranny. If you're looking to have about 600 crank hp which equals out to about 500rwhp, then a FULLY upgraded 4l60e will work. If you plan to break the 500rwhp mark then you can put my word on it that no matter what you do to the 4l60e, it will not hold the power!!! In that case jump straight to the 4l80e. Now I know what you're thinking...(If the 80e is much stronger then why not just go to it anyway?) Well the reason is because its robs a shit load of power from the motor... Where most people see about a 20% loss in power through the 60e. ALmost everyone sees about a 30-35% loss with the 80e. It takes alot of torque to get those monsters turning and its no fun when you dont have enough. To white lightning: since nobody really answered your question correctly then I'll take a stab at it. Let see... the question you asked was, "what are the downsides to removing TM BESIDES failure to the trans?" Well other than failure to the tranny there is none, unless you dont include your torque convertor as part of the tranny, but I do. Hope this helps with most the questions |
#28
sorry. Another downside is buying new tires often, if you're like me
1998 ECSB Z71
#29
#30
link to performance trans site shows alot of the upgradable parts http://www.transmissioncenter.net/4L60E.htm |
