Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-20-2005, 10:42 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: Re: sway bar conversions
Originally Posted by Nackattack
Sry I did mean sway frnt sway bar(located above engine) not tower.
Above the engine IS a tower/strut bar. Swaybar is UNDER the car attached to the control arms. Only the Civic and Integra Type-R's came with one stock.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 05-21-2005, 04:38 PM
Nackattack Nackattack is offline
Re: Re: Re: Re: sway bar conversions
Well alrighty to clarify, I have frnt tower(above engine bay) and I believe that is it. Am I going to want toget rear tower or rear sway first?
Old 05-21-2005, 08:14 PM
Cali Guy
Re: Re: Re: Re: Re: sway bar conversions
Rear swaybar for sure. A rear tower bar won't do you very much if anything, they definitely don't reduce sway.
hessemer69 on AIM
Old 05-21-2005, 08:15 PM
Cali Guy
hessemer69 on AIM
Old 05-21-2005, 09:28 PM
Kven's Avatar
Kven Kven is offline
I know for sure that the 91 Accord LX has a front sway, and have read about the Prelude having front sways(but havent checked in person), so im pretty sure the civic and integra-r arent the only ones with front sways...
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 05-21-2005, 11:23 PM
Cali Guy
I meant CTR and ITR only for upper front strut bar. MOST Hondas except usually for DX's and sometimes LX's don't come with a front sway. All Preludes (6th gen at least, maybe 5th gen too) come with a front swaybar.
hessemer69 on AIM
Old 05-24-2005, 10:26 PM
The rear sway bar only assists the springs and shocks right. Are the springs and shocks the majority of the body roll. I just got some koni reds, and I know that is going to stiffen everything up greatly seeing as whoever dropped this car didn't change the shocks. HOw much will sway bar make a difference after shocks are installed?
Old 05-25-2005, 12:04 AM
Cali Guy
A BIG differance unless you're running at least 12kg (738lbs.) rate springs or higher. Reds can only support about up to 500lbs springs or so if even that much.
hessemer69 on AIM
Old 05-25-2005, 10:16 AM
Any Idea what the spring rate of Skunk2 coilvers are??? I know they are not nearly that high!
Old 05-25-2005, 10:23 AM
Oh neverind, just found this..."If you want stiffer springs, the 94+ teg coils will fit on a 92-95 civic. The Skun2 teg ones have a 550lbs/inch front rate and 450 rear. "
Are these pretty stiff though? I don't know what is stiff and what isn't!
Old 05-25-2005, 07:19 PM
Cali Guy
For Civics the Skunk2's are 500lbs front and 400lbs rear. How stiff? Ehough the start rattling everything in your car after a couple months, and possibly make your back all sore. That's 9kg front and 7kg rear in metric terms. My Teins are currently 559lbs (10kg) front and 336lbs (6kg) rear. At the stiffest dampening setting, they are painfully stiff.
hessemer69 on AIM
Old 05-25-2005, 10:32 PM
Great, So I guess it is about time to start tieing everything down . Will my Koni reds be able to hand such a stiff spring...will I have to get them revalved later on down the road???
Old 05-26-2005, 11:38 PM
Cali Guy
Only way to find out is to call up Koni directly. I'm not sure if they are valved similar to the Yellows or not.
hessemer69 on AIM
Old 05-27-2005, 11:59 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
The information on spring ratesthat follows is directly from Skunk2 themselves (Skunk2, 951-808-9888).
Skunk2 Civic coils have rates of 450lb/inch front and 350 rear, a little less than the 500/400 stated. 94+ Teg coils have 550lbs front and 450 rear.
Now Gorund Controls come with I believe around 380/280 as standard rates, though you can request CUSTOM spring rates and spring lengths for the coilovers. SO you should be able to specify a softer rate as well as a stiffer one, whichever you desire. Unlike Ground Control, Skunk2 DOES NOT offer custom spring rates. Either way, standard civic GC"s are a little softer than standard civic skunks, PLUS they have a lifetime warretny to the origanal purchaser versus a 90 day warrenty like Skunk2.
On a side note, I suppose "too sift" is all relative. I drove around riding on bumpstops for 2+ years back in the day (BIG no no, I forget to cut them down). That is very stiff, regardless of rates, since the bumpstop prevents further comperesion. Now in retrospect, my current proper set-up of Nuespeed Spec SP3 Koni Yellows and Custom Rates ground cotnrols may SOUND stiff (550 front, 450 rear thats 10kg front and 8kg rear in metric terms). However, I find it perfectly fine and plesantly comfortable, despite the fact I suspect most people would disagree. After riding bumpstops that long many years ago, these rates are a breeeze!!!! In fact, I wish I had gone a little stiffer, LOL. Of curse, my shocks can handle it, so I'm all good in that aspect.
Here are some manufacturer numbers you can call.
Skunk2 951-808-9888
Ground Control 530-677-8600
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 05-28-2005, 01:17 AM
Kven's Avatar
I think the japs consider that soft too, since they use higher spring rates for their Touge race cars in the Hondas(i remember the Spoon eg using something like 16k/14s and some of the DC2s going 20k/16k). the touge "courses" are pretty much just any strip in the mountains so theres lots of bumps and stuff.
1988 Honda CRX DX
