Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 01-19-2006, 11:10 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: Throttle body
Shoving more air into a motor is pointless unless you have the accompanying mods to make it matter (ie;exhaust+fuel)
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 01-20-2006, 01:32 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Re: Throttle body
So you are assuming that the stock fuel system runs at 100% capacity and will not be able to keep up with the extra air from a bored TB.?!
Think about it, the engine is still going to consume the same amount of air, a little more, but nearly the same, the stock fuel system can handle a <5% increase in volume.
By installing a larger throttle body you are opening up the "bottleneck" to increase efficiency. Think of it as removing a restrictor plate. Your engine is not going to consume more "massive" amounts of air, unless you increase displacement or turbo/supercharge it. You will notice a power gain as the motor does not have to work as hard to pull in air on the intake stroke.
Example: Imagine a 10mm TB, the engine will be using so much of it's own power to "suck" air through that tiny hole it starts creating a vacuum in the intake manifold, so you will have less-dense air entering the cumbustion chamber and hence, less power. A larger TB will allow the engine to effortlessly take in air and you'll get the most-dense air that our atmosphere can provide.
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 02-28-2006, 06:55 AM
Familyguy88 Familyguy88 is offline
Re: Throttle body
So does anyone know how much power this will give him?
Old 02-28-2006, 09:33 AM
WS-Enterprise's Avatar
WS-Enterprise WS-Enterprise is offline
Re: Throttle body
you could run a 62mm throttle body and you might notice a few HP gained.. but the most you will notice is the quicker throttle response
