Old 05-06-2005, 10:49 AM
drnitrus's Avatar
drnitrus drnitrus is offline
Re: Re: Re: civic drag car
Originally Posted by bigfrit
I have to agree with what Will said, greatness & quality
Although I have a question (cause I ve never seen any dragcar in real life ) , do dragsters usually have diffusers?
Olivier
Some newer ones do. I got the idea from this car. If you look at the indent in the body where the wheelie bars connect to the body it has a diffuser there so it doesnt need a wing.
Old 05-06-2005, 11:12 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: civic drag car
im sure that it prevents lots of air from getting under the body and preventing the rear of the car from lifting. much as a wing would push the car down. the only thing i see wrong is that is a RWD and your civic is a FWD
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 05-06-2005, 12:23 PM
drnitrus's Avatar
The pic might not be too clear but thats actually Chris Rados FWD Celica. The fatty slicks are actually the Front of the car.
Old 05-06-2005, 12:27 PM
bigfrit's Avatar
bigfrit bigfrit is offline
Re: civic drag car
That's quite mad! thanks for the info and the pic!
Olivier
Old 05-06-2005, 10:24 PM
white97ex's Avatar
Re: civic drag car
oops my bad. i didn't inspect the picture close enough. lol. thanks for correcting me! can't wait to see more of this.
Old 05-09-2005, 09:27 AM
drnitrus's Avatar
Talking
Small update--Got a couple of other things made. I started to work on the rear axle
Small fuel cell
Breather tank/Oil catch can
Wastegate
Blowoff Valve
Cam Gears (timing belt soon to come)
Small Lightweight battery
Still have to add a dump tube to the wastegate but that will be later on once things start getting assembled.
Sorry for the crappy pics, bad lighting. Let me know what you guys think. My work area (in the basement) is under renovation, so as soon as thats out of the way I will start painting and assembling some of this stuff. In the meantime back to the styrene pile.
Old 05-09-2005, 09:56 AM
white97ex's Avatar
Re: civic drag car
WOW. awesome scratchbuilding
Old 05-25-2005, 10:28 AM
drnitrus's Avatar
Update- This will be the last one for a little while cause Im gonna go away to visit family for a few weeks. Anyways got some more stuff made. I had to make a rear section to mount the rear axle and suspension. This section will eventually be braced in with the cage. Made rear shocks, made the pedals with the brake and clutch fluid reservoirs. I made a new crank pulley and a oil pump for a dry sump oil system. The pump will mount on the block and I needed a new section on the crank pulley to mount the belt that will drive the pump. Theres a tach and some guages, and started making the aluminum door panels. Some of this stuff is not finalized and some stuff might not look like much but once it gets painted and assembled it should look pretty cool. Enjoy. Feedback welcomed.
The front end is almost set. I still have to sand some minor spots then primer and re check for high/low spots
Old 05-25-2005, 01:11 PM
white97ex's Avatar
Re: civic drag car
i've got some trouble seeing the larger images when i click. but it looks good. are those door panels out of aluminum? they look awesome.
Old 05-25-2005, 01:23 PM
GvEman's Avatar
GvEman GvEman is offline
Re: civic drag car
I cant se your pictures
Best Regards
Anton
Old 05-25-2005, 03:03 PM
drnitrus's Avatar
Re: civic drag car
Sorry guys. The hosting site I use seems to be acting up today. Check back every so often they might be back up then. I guys you get what you pay for. And since its free....
Old 05-25-2005, 03:04 PM
drnitrus's Avatar
Yeah those are aluminum.
Old 05-25-2005, 03:06 PM
autobot 101's Avatar
autobot 101 autobot 101 is offline
Re: civic drag car
I like the way how you scratch build parts.
THE POWER OF DREAMS
Mico Pena
Old 05-25-2005, 03:19 PM
GvEman's Avatar
Re: civic drag car
Looks sweet! love all your scratch building!
Best Regards
Anton
Old 05-25-2005, 03:20 PM
drnitrus's Avatar
Thanks. Since they dont make a kit like I want to build, I have to buld everything to my liking.
