Old 05-05-2005, 07:31 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Killswitch
Originally Posted by Robs71Nova
The easiest way to install a kill switch is to find the power wire to the ignition coil, and install the switch inline with this wire. When the switch is off, no spark, and the car will not start. However, for this type of switch I recommend putting this switch inside the car somewhere, in a hid place. Somewhere under the dash, or whee only you know whee it is. Be careful not to accidentally swotch the switch off while the car is running though, because it will shut the car off. If you have a MSD box, your going to want to slice into the green wire running from the MSD box to the ignition coil.
Rob
yes that is the wire I was talking about. I was trying to figure out the color of it.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 05-05-2005, 04:09 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Hood Locks?
Anyone know of any way to lock a fiberglass hood that uses the pins, not the factory hood latch?
I thought of using the locking hood pin sets by Mr Gasket, but they say they MUST be used in conjunction with the factory hood latch system. Is that complete BS or a valid warning?
I'm at a loss, I'm gonna put the kill switch in next week, but if anyone can open my hood, they could always do something ignorant like cut the plug wires, bend the fuel lines or something.
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 05-05-2005, 06:14 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Killswitch
my suggestion, dont put the kill switch on the wire to the ignition system, if someone knows what they are doing they might be able to easily track that wiring, find the splice, and the kill switch. Especially in your car with an open engine bay, and not alot of wiring. Instead, find the fuse circuit that feeds the ignition system, and install the swich splice under the fuse box on the power side of that fuse, and then run the wires out with the rest of em so it dosnt look obvious. then run the wires into the car, and if need be back to the trunk, but one that ive heard of that i liked was benith the removeable ash tray.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-05-2005, 09:17 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Re: Killswitch
ooo you could put the switch on the main power wire that goes to your fuse box so nothing at all gets power enless the switch is turned on, enless its something thats direct to the battery....wait is there a fuse for ignition? wel if not go for 89 irocs idea...or just go with his anyways if you like it better...but yeah i agree with the switch under the removabole ashtray. my girlfreind showed me that in my car...she said i could hide stuff in there and pointed out that it came out.....kinda odd but whatever
Old 05-06-2005, 09:44 AM
Earlsfat's Avatar
Cheesesteakoholic
Re: Killswitch
Beautiful. Already ordered a switch I'll check it out his weekend, let you know.
Old 05-06-2005, 10:10 AM
Hypsi87's Avatar
Re: Re: Killswitch
that mighe be too much current, unless you wanted to run a relay.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
