Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-04-2005, 09:28 PM
MODIFIED_GSR MODIFIED_GSR is offline
Re: integra sir-g ???? what the?
ya a typies suspension is toooo tight for a gsr but in my case al im doing is draging. and ive takin three out so far. and as for my ecu upgrade im running it off of a untouched p28 ecu gonna get a chipped ecu. so its either my motor has internals i dont know about or my friends cars arent running properly. ???
Old 05-07-2005, 11:09 PM
LowTegg LowTegg is offline
the type-r motor compared to a gs-r are similar in alot of ways but the type-r has alot of minor upgrades that the gs-r doesnt have that makes it produce roughly 20 more HP like slightly different cams valves, springs/retainers, piston rings and the type-r 4-1 header compared to the gs-r 4-2-1 header, PLUS the LSD that the GS-r doesnt have which makes alot of difference on take offs also the type-r does have much better suspension setup than the gs-r like someone said type-r are slightly lowered, much better antisway bars and the type-r is also lighter than gs-r... gs-r does have better low end power but the type-r should still smoke the gs-rs in turns and drag someone with a gs-r beating a type-r either something about the gs-r that the driver doesnt know about making it faster than it really is(like internals) or the type-r driver sucks ass at shifting(if thats the case, then he or even she doesnt deserve to be driving the type-r)
Old 05-08-2005, 06:54 AM
kenng kenng is offline
Re: Re: integra sir-g ???? what the?
very detail!!!
I've upgraded mine in everyways, engine, exhausts(keeping 4-2-1 stainless), brakes, suspensions and transmission!
heh heh
Old 05-08-2005, 05:53 PM
hmmmmmmmmmmmm
Old 05-10-2005, 02:35 PM
Crippy's Avatar
Crippy Crippy is offline
as for the gsr having better bottom end ... WRONG !! the jdm sir-g motor has higher compressions pistons , same as the U.S type R , giving it the same cr , and around the same peak torque #'s ... however the type R hits about 120 ft of tq at about 3 thousand rpm's , and it has lsd , shorter geared tranny and its lighter than the gsr ... no way in hell should a gsr or sir-g be beating a type r in relatively stock form ... not down low , up top , and espeacially not thru the twisties !!
oh yeah , keng why did you put a type R sticker on your car ?? its still not a type r !! after reading your set up , your car is NOT ANYTHING CLOSE to a type R !! all the OBX and tenzo R bs that you have doesnt compare to authentic type R parts ... you dont even have the type R body kit ... i doubt its a 5 lug conversion either ...show me a pic of your engine bay , do you have the valve cover ?? you still need a light weight hatch and cabon fiber peices for the inside of your car ... a gsr is tight for what it is ... dont try to make it something that it isnt ...
2001 GSR ,
94 jdm b18c sir-g swap , i/e !!
Old 05-10-2005, 04:29 PM
I haven't got the engine done fully at the time I got the stickers, been working on it for the last 10 days, got the car back on the road this afternoon with Mugen internals and ECU, Skunk2 CAMs, but I'm still keeping the SIR Intake, I will put it on a dyno with the SIR intake and also try with the Type R intake next week and see which one is better to have!
I got most the Carbon Fiber, got all of them throught the Center, trying to get the door handles and air vents on the sides!
got a 260KPH Dash though, JDM Type R dont have that, USDM ones are different again!
with the Mugen internals and a spoon lsd only parts I need to get now is the final drive!
I couldnt be bother changing the hatch, why I dont know, and the Type R bodykit is optional anyway, they come standard with front lip and rear spoiler
I have a dyno sheet of my car pulling 133ft/lb before I put in the Mugen Internals, also another dyno before christmas pulling 137.6ft/lb before I changed the exhaust system! I lost torque after putting on the stainless steel exhaust
the 5 lugs are on the 98 onward JDM Type R but not on the JDM Type R before that year
the reason why i didnt buy a Type R is because I was gonna rebuilt the engine with Mugen Internals anyway so why bother pay more than double the price for a Type R when there is only the difference in 40kg in the weight, lose most of that weight easily!and spend the money on the engine and better suspension and brakes upgrade which i may do anyway with a Type R, so I pretty much be doing the same i do with this SIR, thats why i bought this car!
Old 05-10-2005, 08:13 PM
good man sounds like a plan to me. isnt that a gs-r throtle body????
Old 05-11-2005, 06:27 AM
yea, I'm using this first on the dyno and have it tune, then I use the type r one and tune it again to see which gives the best result, I want to try the SIR intake because it should gives better performance if its set right by the design of it! no harm trying it!
Old 05-11-2005, 10:38 AM
pepsihatman's Avatar
pepsihatman pepsihatman is offline
Send a message via AIM to pepsihatman
Let us know the results!
~!~David~!~
1998 GSR, 86k miles, AEM CAI, DC 4-2-1 Ceramic Header.
Old 05-11-2005, 10:39 AM
Crippy's Avatar
all type R's are 5 lug ... and no us type r has a 260kph gauge cluster ... we go by mph here in the states ... and EVERY type R has the body kit ... i will believe your tq #'s when i see them ... cause for some reason your gsr puts down more tq with stock internals than any other gsr ever built ... kinda funny
2001 GSR ,
Old 05-11-2005, 11:39 AM
here's the dyno I got in March just gone, with a full stainless system on from header!
can't find the sheet I got before christmas, it might show up itselfs at some stage, almost no different in horse power compare to stock!
I dont really care about the horse power, no use for huge HP in this country! just want more torque!
have done 0-100kph using Apexi RSM to take the time reading, but I dont have the G-sensor yet, wheel spin at first gear, got 6.67 secs, trying to do it with a good take off!
our 95 Type R we bought in from Japan has only 4 lugs, but the 98 ones has 5 lugs, I have a VCD from Hong Kong that shows off the 98 on Type R also mention that they use 5 lugs on that year onward!
I know the USDM Type R has Mph and they dont have the yellow needle either! but I dont know what color they lights up, but the one I got is original Type R speedo that reads out to 260kph, which doesn't comes in the JDM models!
and when you say every Type R has body kit, you mean by full kit inclding side skirts and rear extension or just front lip and rear spoiler?
and is it USDM or JDM you on about?
we had many Type Rs in and out here for the pass few years, only one came with full kit, all the rest are only front lip and rear spoiler only, direct from Japan, Euro version of them were never sold here untill 98, even so only some of them on the road has the full kit, and Honda over here saids that they were optional also! must be a difference between the States and Europe, not sure about your JDM imported Rs over there!
P.S. I'm not sure if they got the reading right, the last time I got the dyno done was 176bhp and 137.6ft/lb, now its 181.4hp and 133.4ft/lb, only 5bhp the difference and 4.2ft/lb lost in torque, I'm getting another dyno done hopefully next week(if my ECU turns up)! then use the Type R intake manifold the day after for another dyno! ofcos we get it tune right for each manifold!
Old 05-11-2005, 12:54 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Ummm... the hp reading you're talking about is the hp at the flywheel, not at the wheels. That is a big difference when you're talking about hp. It makes more sense now when you're making that much hp and tq at the flywheel than at the wheels; it becomes believable. And yes the '96-'97 ITR's did infact have 4-lugs.
Old 05-11-2005, 01:10 PM
atleast I didnt lie
we messure with flywheel here, correction from flywheel to wheels!
even honda uses the flywheel HP messurement!
Integra Type R's are 197bhp at the flywheel also! and are 138ft/lb of torque at the flywheel! so I didnt do too bad on torque! it was nearly the same after a complete rebuilt with a tweak of timing and minor upgrade but lost torguq after exhaust upgrade!
also a 95 type r is 197bhp and 138ft/lb in 95 but after 10 years on the road with the increase of mileage and depends how it was looked after, it wont be 197bhp and 138ft/lb today, unless if the car has been really well looked after to mentain the condition like it used to be, we had a dyno day with 7 stock ITR's, I went along after the rebuilt with a Type R flywheel and exedey stage 1 clutch installed with a few other bits, nothing major and thats when I got the 137.6ft/lb and 176bhp, but one ITR got 174.8bhp and 134.7ft/lb which was a 96 but suprisingly a 95 ITR was 189bhp and 136ft/lb the best one was 196bhp and 138ft/lb bang on! all were stock ITR's, these are reading from the flywheel
oh cr*p, I was suppose to find out what color the wire is for you about the fuel line! I forgot.
mind wait for a while and I take a look while I pull out the ECU? save me pulling out the panels all the time! if you still need to know!
Old 05-12-2005, 01:02 PM
b18ls's Avatar
b18ls b18ls is offline
Banned
Re: Re: Re: integra sir-g ???? what the?
Originally Posted by kenng
i dont know then, i was told that the difference in the intake manifold for the gsr, it has better power at the low end, many people told me that!
and many people told me the LS has better low end than the GS-R...
Who cares what people said. Numbers don't lie.
Old 05-12-2005, 06:20 PM
Re: Re: Re: Re: integra sir-g ???? what the?
isn't thats wht I'm gonna do a dyno with the GS-R intake as well as a dyno with the Type R intake to see which is better
