| View Poll Results: How many of us Burn OIL? | |||
| I gotta top it up everday! |
1 | 5.26% |
| I burn 2-4 litres a month |
2 | 10.53% |
| I burn 1-2 litres a month |
7 | 36.84% |
| i don't burn a thing! |
9 | 47.37% |
| Voters: 19. You may not vote on this poll | |||
#16
Re: How Many of us burn OIL?
You should ask, how many of us don't? That will be a smaller list.
98 MITSU GST, 1990 TURBO MOTOR 98 ACURA INTEGRA LS 88 HONDA CIVIC HB 97 HONDA CBR 600 91 HONDA CRX DX 89 JEEP ![]() ![]()
#17
my motor does not Burn any oil... however it is my 3rd motor in this car...
first one Burnt oil BAD! like 1 qt a day... 2nd one (DOHC ZC) did not burn any... but tranny failed 3rd one... not burning but it leaks it quite ofter... Turbo oil pan with leaking return line Road took out oil pan #1 Road took out Oil pan #2 oh well...
2012 VW Golf 3 Door Automatic (Company Car) 2011 VW Golf Wagon 5 speed (Company Car) 2010 VW Jetta 2.5 Automatic (Company Car) 2009 VW City Jetta 5 Speed (Company Car) 2009 VW GLI 6 Speed (Company Car) 2008 VW Jetta 2.0T 6speed (Company Car) 1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold 1990 CRX Si (Built B17a) - Stripped and Crushed 1988 CRX Si -- Stolen 1990 Civic Cx -- Sold 1990 Civic Si -- Parted 1989 Civic dx -- Sold |
#18
i burn about a quart a month, perhaps a quart and a half. put it this way, i usually end up having to ad at LEAST a quart, and sometimes 2 quarts between oil changes.
under my car i can see that there's oil dripping from... you name it, it leaks. obvious leakage from oil pan gasket, but haven't read up on how to get at it to fix it. suspected leakage from tranny.... i'm hoping it's just dripping ONTO the tranny... i'll check the thing eventually, but i haven't had any problems shifting and i changed my tranny oil middle of last year, so i should be fine. (i've aquired propper tubing and syringes for which to do a much easier oil change on my tranny. i just may get at it and change it again for good measure this year.) |
#19
2008 KIA Spectra5 SX 2010 Honda CR-V EX |
#20
I used to use a heavier oil & additive to control the oil burning. Now i went back down to a lighter weight and i'm burning like mad. Maybe one quart per week.
I read in another forum where a guy reduced his oil burning with an engine 'flush' type cleaner, auto rx. This auto rx has greatly helped my motor perform better. But it still burns oil. Runs great, but burns. So i'll try a new PCV valve. Maybe i'll try sythetic also. I don't want to rebuild the engine. Anyone have any suggestions? |
#21
burn 1/4 - 1/2 a quart every 1000 miles. 262k original miles. mechanic says its the oil pan gasket. I would change it myself but my dad says no.
#22
i burn no oil anymore since the engine blew on easter..ordered the b16a1 yesterday and should put it in next weekend sometime
98 Jetta GLX VR6-vroom vroom!! 91 CRX Si-R..busted..
#23
Always see the upside man!
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
#24
About a quart every 3000 miles, sometimes more depending on how fast I go, usually go over 80 all the time. Car is an 88 wagovan with just over 202,000 miles on it.
#25
Does anyone know of a way to reducle oil burning? New PCV valve?
Does 'blow by' usually happen in one spot on 4rthgenerations? Is there one repair that usually fixes this? I can switch back to 15W from 5w but i would imagine this would reduce MPG; maybe even slow down the motor. I read somewhere that Lucas UCL might help with blow by. The engine runs very good except for the oil burning. Do I need a new one? Do i need a rebuild? I already changed the rings around the spark plugs that came with the the valve cover gasket. Also, I've had EXCELLENT resultS with Auto Rx and i strongly recomend this product. (It's similar to a 'Gumout' or 'Gunk' type flush) Suggestions welcome. |
#26
I think switchinng to sythetic would reduce oil burning. But considering I'm loosing almost one quart every 400 miles would that just be throwing money away?
#27
#28
You could try running the 5w with an oil additive too. I dont know if you tried that yet. Mine used to burn oil more than yours so when i changed it last i put in the 5w30 and an additive that is supposed to help sealk around the rings and i have only burned about 5mm down from the full mark on the dipstick in 2,000 miles. I cant tell if the MPG went down because it jumps all over on everytank.
#29
Thanks CPolaris,
What kind of additive did you use? Restore? Lucas? Was it super thick like Motor Honey? I'm dreading the idea of having to pay for rebuild of a motor that runs wonderfully except for a little oil burning. Compression is fine. |
#30
The stuff that i used came from napa, i think the brand was resolute and the stuff was called ringseal. Yeah it was real thick and hard to get out of the bottle. Its saved me money from not needing to buy more oil all the time.
