Re: Re: fan malfunction here too!
Originally Posted by ssseeeaaannn
If you fuses check out ok and relay is fine. It seems to point toward the ect sensor. The problem on mine was it was plugged in the wrong way. Someone told me it should only plug in one way but somehow mine plugged in the wrong way. The sensor cost me $7.99 so its not going to be an expensive check. After i changed the sensor my fan is kicking on right around 3/4 which i guess is normal. The main reason why it is heating up is your fan is not kicking on which is controlled by the ect sensor.
I'm just so confused, because one day it just started over heating. It's not like it always went up to the 3/4 mark and the fan would kick in. So would the ECTS cause the car to actually over heat? Or is there somethin else wrong?
Saturn and a Ford, should they both be owned by the same person?
