#16
Re: My Rover 75 randomly won't start
Thanks to reading other 75 owners' problems with starting and taking the advice of the solution possibly being a new camshaft sensor, I was able to tell my 'Rover' dealer (now a Ford garage) in advance and they had the sensor on stand-by when I visited today for an urgent diagnostic check. I'd begun to call-out the AA on consecutive days with the non-starting problem, both frustrating and a tad embarassing. Hurrah, the diagnostic check kept coming back to the camshaft sensor being the culprit. Thanks for all the help.
#17
wow, who would have thought my desperate little post would have done so much good in the end (and kept so many pounds in pockets where they belong!). Great news! Laura.
#18
I am so gratefull for everyone posting this information. My Rover 75 2.5 2003 has exactly the same fault. It started four weeks ago. Every now and again it just turns over and over and over. I disconnected the battery thinking it was a computer fault. Once my computer average speed bit etc went wobbly and it fixed that. I think it was co-incidence that after a period of time it finally starts. The only thing I find of releif at the moment is that everyone says it eventually starts...other than this and a back door that wont open its a fantastic car and a joy to drive!! Anyone got any more advice than just change the two sensors?
#19
Hi,
i had a problem with no starting once and it was the fuel transfer tank..( a small container which stops the car running low on feul when a low tank and cornering) sometimes these can come unscrewed a half turn and loose vacumme)..it is a known problem with the 75s
kiwi 75
#20
Want2Bhappy]
Hi this is such a good site and I really appreciate everyone's imput. I am really hoping that this will solve my problem, which seems to be the same as everyone elses. I have just ordered a new sensor off the internet which will hopefully get to me by thursday. Will definitely be big smiles all round if it works. If not will coming back for more ideas!!runaround |
#22
I'm encountering a similar problem with my Rover 75 Connoisseur.Random start refusal .But today I got Traction control in the computer screen on the dashboard.Can anyone tell me what could be the problem ?
#23
Hi Boxer Girl,
yes we too are having difficulties in starting our Rover 75. So far I have managed to ascertain that it could be- 1) Camshaft and cam sensor 2) Power steering sensor 3) Fuel transfer tank 4) Immobiliser I am very reluctant at this stage to take it into a garage. Its like giving them a blank cheque! Our main symptoms are that it wont start randomly and there is no telling when this could happen. Its ususally when we go shopping and the car is left for an hour or two so this would suggest it occurs when the car is warm. It starts every morning without fail. we decided to test this one day so when we arrived back home (from an extended shopping trip) we fired her up again ---And she totally worked! It was so wierd. When we wanted it to fail it didnt! Im lost!!! SOMEONE PLEASE HELP ME!!! |
#24
We've put up with this for over a year. We've noticed it's more likely to occur after 30 minutes and less than 2 hours of having been run. When it happens we just have to sit it out. Once we called out the AA and after a diag check he suggested a camshaft sensor might be at fault. He also indictaed after a time it usually resets itself (which is what seems to happen). He also suggested turning the engine over for more than 30 seconds might do the trick but it didn't work for us. We may have to bite the bullet and replace this sensor. If it works out we'll let you know which one and how much it cost. In the meantime, maybe a half-hour chill-out is not such a bad thing? Don't answer that, it's just wishful thinking!
#25
That's really great!
If you have a problem in your parts, I think it is a must for you to change them.
Rover Parts - Find Rover parts new and used. |
#26
hello all,
i have seen what you have all put so i have ordered a camshaft sensor and a crankshaft sensor. as im also having problems with it not starting when hot or just even warm.... drives like nothing wrong but i cant keep going into shops with the car running as i dont want to turn it off incase it does not want to start for couple of hours...also inbarasing when i call the AA out and then it starts at the first turn of the key.....will post if it fixes my problem...... middle of next week sometime
#27
hi every one..... i have solved my problem £70 and 5 min under the bonnet...camshaft sensor...thanks to all that posted so i could find my problem....better that a huge garage bill, do it your self.
#28
Re the problem with the traction control lamp on, check the cable for the traction control is not broken, it is housed in a small unit that looks like a wiper motor unclip the cover and check the wheel does not rotate back and forward, it is connected near the throttle cable at the throttle body
#29
Hi all, just joined this site and this is my first post. Initially wanted answers to my Rover 75 having intermittant starting problems. Just had it down my mates garage, put it on the computer and came back with 'fuel pressure problem'. He merely tapped the secondary fuel pump (silver thing at rear of engine) and lo and behold it started! New one costs over £200 + vat so guess i will just put up with tapping it now and again till it goes altogether. This just might work for someone if they get stuck with car not starting!
Happy new year to all!!! |
#30
Hi, just read the threads on the rover 75 diesel starting problems, I have the same problem, I'm mechanically minded and have so far established the following.
The car starts with easy start. The problem only occurs when the car is hot Both pumps are working fine Cam sensor disconnected and easy start used to prove if cam sensor working. Once cam sensor disconnected easy start starts engine but then cuts out, reconnect cam sensor and used easy start again and engine starts and runs thus proving cam sensor working and firing diesel in at correct time. Once the car is running it idles perfectly and revs evenly throughout the range even to The red line without an issue. Car still maintaining an average of 50 - 55 to the gallon, no loss of power with only one exception so far, pulling off from a busy roundabout, gunned it away as the roundabout was like a racetrack, when the revs got over 4000 , she cut out ? Bottom twitching moment, pulled off, pulled bonnet, tried to start, no avail, grabbed easy start, quick squirt and started and drove fine. I do 150 miles per day driving to work and back, motorway for 90% of it, never a problem drives perfectly. I do love the old beast and she drives great but the mot due in April and I'm undecided as to if I should bite the bullet and give up on her or persevere and do the minor work needed for the mot and continue trying to figure this out. Any advice guys please. Many thanks Gaz |
