| Non Specific This is the forum to post and generalized racing questions. |
#16
Re: Water/alcohol injecton (and why alcohol is better)
Good writeup...I never knew that you couldn't just run a bit of the windshield washer tank and pump. Good to know before I got bored and wasted time, $$, and tapped my plenum.
I do however plan on running propane in the future...depending on my turbo upgrade decision (I'm still flip-flopping between 2 options) But if I go with the larger, I'm going to be running propane so I can really boost on 94 octane pump gas. I know in general it isn't as popular a choice as alky, but as far as I can tell it seems to be more popular amoung the 3S crowd...
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
#17
Re: Re: Water/alcohol injecton (and why alcohol is better)
Damnit Igovert500, now you've got me thinking, if I could drop my combustion chamber temp down and run more boost or add another 50 shot of spray, Hmmmm How would you explain it to the guy doing your emission check? Him: What does your car run on? You: Well it uses some gasoline, alittle propane, a touch of water with a side of alky and once in awhile it's known to consume large amounts of nitrous when needed. |
#18
For water/alky injection what is better, a variable system based on boost pressure or MAF readings?
And Igovert, what two turbo choices are you flip floping on? I like the price and performance of the 13t WRX turbos.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
#19
Sticky?
If I may add a bit here
![]() I run water injection in Hyde and I would never modify a boosted car without WI ever again. I run 60% distilled water and 40% methanol. The only reason to run methanol is as an anti-freeze for those of us in places that get that cold. Detonation control (affective octane) of water is much great than a water/methanol mix. In my opinion, I would not run alcohol injection or use methanol as a fuel source. I would prefer having the proper fuel system for my target power level and use WI as (a) safety measure and (b) to allow for a little more agreesive tune. With the current state of my engine, I am using it more for damage control. Another reason to choose WI over alky injection is that no racing body that I am aware of disallows it. However, several racing organizations (or classes within) do not allow running alcohol. Just my 2 psi. Happy boosting.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment |
#21
Sounds like a good 2 psi to me. Another happy customer.
It's been around along time and most people think cause it's water wouldn't or doesn't have much value. Tell that to the guys that use it. I swear by it. |
#22
200,500 miles engine pushing 24 psi of boost ... I wouldn't try it without race gas and water injection
#23
you have to go boost. The reason is that MAF readings are not really related to boost. Thats why you can have your MAF before your turbocharger and it will still work. Remember, boost is what creates the heat, not your airflow. Personally with my new ice water to air intercooler, I don't have to start spraying untill higher boost levels so, I don't think a progressive kit will be any help.
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
#24
i like alcohol injection on the weekends...
RX-7 TII |
#25
Re: Re: Re: Water/alcohol injecton (and why alcohol is better)
1 stage triggered by a pressure switch, 1 by throttle at wide open micro switch and the other by the nitrous selenoid power. I don't want to flood the engine with large amounts of W/A but want levels needed for different power needs. I setup a friends car that had a large 2 stage nitrous setup with a 2 stage W/A setup also. It worked super and allowed him to keep his timing set for best power without spray while still maintaining good EGT readings with spray. |
#26
Hrrm, well I think I'll be upgrading my turbos before getting an injection system, stock intercoolers are fine for now.
