| Off-Topic Talk about anything other than cars. |
#16
Re: It never stops...Story AND ISC Question...Please Read
From Dave Mertz of the DSMlink forums, the 1g TPS shouldnt affect the idle speed control system. Dave is one of the two creators of DSMlink, probably the two most knowledgeable poeple on the planet when it comes to DSM ECU operation (excluding the mitsu engineers that created it of course). This makes me wonder why it helped in your case RSLaser. Are you sure you didnt inadvertently change anything else at the same time?
The 2g sensor includes the Throttle Closed switch signal (2g TPS has 4 wires, 1g has 3). If TPS is more than 1 or 2%, it will also make the ECU believe that the throttle closed switch is open, meaning the throttle plate is open, which will tell the ECU to not bother with closed loop control of the idle speed control. On a 1g, there is a seperate switch for this, on the firewall side of the TB right on top. This is another good thing to check on a 1g. Be sure the switch is closing when the throttle plate is closed. It is adjustable, and I believe the factory manual calls for turning the switch body in until the switch closes, then another 15/16th of a turn. Use a multimeter to test the switch. I beleive it simply grounds the single terminal on the top of the switch to the TB, so it is easy to test. If that switch fails or falls out of adjustment, closed loop control of idle will be eratic at best, probably impossible.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#17
could it be that the timing is off. I heard if the idle is set to low that it surges like that.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black) Stock 93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red) Cosmo Racing Air Filter Brembo Rotors 14b turbo Faze Boost Gauge Faze Air/Fuel Gauge Dual Gauge Pod Megan Racing 3" turbo back exhaust 450cc Injectors I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested |
#18
I am somewhat doubtful of the timing, and my idel is set perfect. It was fine and then all of a sudden it wasnt so I know my idel is okay.
I found that with the ISCM I put in, the revving would not stop it would continue on. With the one I had in before it would rev up and then just stop after about 5 mins and would only do it if the car had sat for a while. With the other one, it would constantly do the revving thing which leads me to believe that that ISCM is worse than the other one. Would this also mean that it is clear the the ISCM is the problem? Or could it be something else? thanks!
"You can have everything in life you want if you will just help enough other people get what they want."
#19
I talked to a mechanic and hes going to hook a computer up to my car on monday or tuesday and ill poast the results then.
