| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
#16
Re: Tein or Omni?
omni's are complete coilovers, but youll still need the front forks(as with most other aftermarket shocks for hondas).
if you are installing a complete coilover, you dont need the spring compressor. the spring compressor is just to seperate the spring from the damper, but if you are replacing the whole shock absorber assembly you wont be needing to remove the spring from the damper. the Omnipower Street and Sport dampers are the same(just springs are different). the valving is biased towards Sport so it doesnt match as well on the Street coilovers. The reason they dont offer adjustable damping is because they designed it to run perfectly with those springs(with the Sports). |
#17
so im better off going with the sport set up because the springs are more suited for the strut they are on compared to the street that has less of a spring rate?
#18
Re: Tein or Omni?
omni has both sleave and full coilovers out
tein has full coils and springs tein is a laughable rip off imo I might be selling my custom rated skunk 2s and koni yellows for omni street if i keep my car. Thats how highly a avid autoXer thinks of them. |
#19
Re: Tein or Omni?
Re: Tein or Omni?
i live in nyc...so potholes r a dime a dozen..but i avoid them now so i'll avoid them once i get the omni's too...
but i think im just gonna get the sport and get it over with... i dun think the ride will be so much worse than the street setup.. springs rates aren;t really incredibly higher... |
#21
Re: Tein or Omni?
Something to look into and the MOST important factor for me in a true full coilover, is it able to be ovehauled? Teins are, in fact I'm going to get my rear ones revalved soon here. I've already upgraded the springs on all 4 to the stiffest that the factory valving on them will handle. I'd look into if Omnis can be revalved/overhauled the way that Teins and other brands can be. Sure Tein is a name, but you're also paying for quality with them as well as other important key features like shock dampening which the $650 Omnis DO NOT have. They are only height adjustable. Also to clear up some false information here, Tein DOES make some very affordable products. Tein Basic kit (there height only adjustable equivallent kit to Omnis) can be had for UNDER $700 if you look and shop around enough. They aren't so expensive in comparison if you KNOW what to look for and where.
Silver '00 Civic EJ6 Coupe PureHonda original member since Feb. 2000 D-series revolution For pics of my baby, click here! All rights reserved... All BITERS served! "The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket." i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift hessemer69 on AIM |
#22
Re: Tein or Omni?
well i'm not going with either tein or omni acutally..
i'm getting koni/neuspeed sp3's with ground control sleeves... i've heard great things about them..the shocks and springs...and they r great for all type of driving... gettin em next week..can't wait... |
#23
Re: Re: Tein or Omni?
#24
Re: Tein or Omni?
well if it matters, lots of the honda racers like to use Koni Yellows with custom-rate GC coilovers. from what i hear, if you order the Koni's with the GC coilovers direct from GC, theyll revalve it to match the springs(the Koni's are rated to about 400lb but lots of people put 500 or 600lbs, it works but wear increases faster; a revalve would fix this).
btw, what is "shock dampening"? if its what i think it is, i would think all shock absorbers dampen "shock". |
#25
Of course ALL shocks dampen shock, but some allow adjustment of this. For seeming so knowledgeable about this stuff, someone like you should know about adjustable dampening I would think.
#26
Re: Tein or Omni?
the only adjustability i am familiar with is rebound and compression; i was thinking you meant shock as in something like high-frequency vibrations maybe? i dunno(most people just say dampening, i guess that threw me off some how lol)...
the thing about Koni Yellows handling 600lb; Koni recommends only up to 400lbs, although many have run 500 without a problem. They(Lee Grimes of Koni) said that the 600s cause increased wear; resulting in a early rebuild. btw, im no suspension expert, i just share my knowledge of things ive read(mainly from suspension websites) and experience. |
#27
http://www.bose.com/controller?event...components.jsp |
#28
SilverY2Kcivic is right on the rates yellows can handle. I have personally called and talked to people at Koni many times myself. I always call the manufacturers myself, talk to them directly and do research before I buy. The Koni techincal and repair department has told me on several occasions, directly, that the Koni Yellows can handle up to 600lbs/inch. I called and asked then several times before I bought my set-up. The Neuspeed spec (SP3) ones have a 20mm shorter shaft, 5 perch adjustability versus 3 and slightly stiffer valving.
Also for Koni Yellows (SP3's) and Custom Rate (550 front 7" springs front, 450 7" springs rear) GC's...Great set-up, I have no complaints...exepct I wish I'd have gone a bit stiffer, somewhere between 600/500 - 650/550). It's a great set-up though. Also, both Koni AND Ground Control offer lifetime warrenties to the orignal purchaser, so SAVE the reciepts (FOr comparison, Tein is a 1 year warrenty and Skunk2 coilovers have a 90 day warrenty)..and Koni's are also re-buildable...also Koni can make the Yellows double adjustable if you so wish (for a fee of course, lol).
![]() ![]() It's just that easy folks... mind the forum guidelines and we're cool. Empty Pockets Racing Member #6 EPR Member 4 Life |
#29
Re: Tein or Omni?
yes...precisely why i went with that combo...
gc makes sleeves specifically for koni that'll make it a perfect fit... so even though it might not be a true coilover...it offers the same type of advantages... also i didnlt order the custom rate springs although they r the same price.. i think off the shelf the gc sleeves are about 350/300.. and i think that should be more than sufficient for me right now... it'll be stiff enough..and if not i can always get it redone... |
#30
