| Non Specific This is the forum to post and generalized racing questions. |
#16
Re: ^^ you guys posted too fast!
2) Horsepower is not some...thing, that just comes and goes at different speeds or RPM's, horsepower is always there, it's just that engines operate at different powerbands through different RPM ranges, the reason the mitsu got pulled on is because it was waiting for the huge turbo to spool up on it, without that turbo that car is probably a high 15 ssecond car. And yes gearing does play a factor in it, a huge factor. 3) Generally Diesels produce more torque because of how they operate, you take a gas engine like the 1.8T the VW's use and look at the TDI, and how general combustion works in each. Gas engines operate with air, fuel, and spark each revolution, and combustion pressure isn't nearly as high. Diesel engines on the other hand only require fuel and air, and glow plugs to merely start the combustion process, after that diesel engines operate with high combustion pressures, and this is due to the fact that diesel gas only requires compression, the pressure is so great that it creates it's own combustion without the use of spark, there are other factors but im trying to keep this short.This is a great explanation here(and i'm not that good at explaining things) 4) When you strap a turbo on a car, it creates displacement, much like cubic inches on an engine, so not only do you get horsepower, but you also get good torque with turbo's, notice turbo's are also used on diesel engines; low compression ratio's are ideal for turbo's. 5) That statement is not necessarily true, it's all about the type of engineering that goes into an engine, and the components used. There's more factored in to an engine's horsepower and torque than whether it's SOHC or DOHC. Compression ratio is merely where combustion takes place in the cylinder, it can have an effect on horsepower and torque readings when you rebuild and engine or set timing but in your case it's just two different engines. 6) It all depends on the car really. Horsepower and torque are always there together, other than that i think the debate should be, do you want a car that gets good gas mileage, or a gas hog? And there is more that gets factored into a car besides horsepower and torque, such as gearing and horsepower and torque RPM range, also, how it gets the horsepower, N/A Turbo or S/C. 7) Once again, HP and Torque work one in the same, adding HP will at the same time add Torque, people are just more commonly associated with HP than Torque, so they advertise that. Messing with the timing, or adding a component that adjusts timing can increase horsepower and decrease torque, or vice versa...it all depends on what you add and what it does. There's a shit load of factors that go into increasing horsepower and torque. There's also a lot of factors that go into properly tuning a vehicle, some people think you can just throw on a turbo or supercharger and be done with the car, not knowing that in the long run, or right away that there's many other things you have to do for the car to perform properly; such as fuel and ignition system, gearing, timing, new RPM powerbands(when to shift). Questions like, will i need a chip with these new injectors, fuel rail, and pressure regulator that i just put in to compensate for the huge turbo that i put on my car a few weeks ago, and what chip will i need for it? There's a lot to learn about cars, and you wont learn it all in a period of months, it takes years of experience and mistakes to know about cars and working on them/tuning them properly. I hope this helped, cause i'm really not good at explaining things, and i hope i didn't confuse you even more. This is stuff that i know and just try to put it to words, which isn't easy. Last edited by Z28Josh; 04-03-2005 at 04:29 PM. |
#17
Re: Re: ^^ you guys posted too fast!
Awesome, thanks for all that Josh! Didn't mean for someone to take so much time answering
Definately helped answer some of my curiosities though. I know a lot more about cars than I did when I got mine (when I knew nothing), but its definately a life-long learning process. Good thing for the internet, or I wouldn't know a damn thing. I don't plan on adding any forced induction to my car, its a daily driver / my only car, so probably just intake/chip/exhaust at some point to make it a little more peppy. |
#18
Re: Re: Torque vs. Horsepower
Ok first of all, there is not Air/Fuel mixture on a diesel einge. When the piston is on it's intake stroke, all the engine does is bring AIR only into the cylinder. Then when the cylinder is compressing the air on the compression stroke. When the piston reaches the correct postion, the injector is actuated and fuel is shot into the cylinder at 20k+PSI. And common compression raitos for a diesle are in the 15-18 to 1 but since they have not Air/Fuel mixture to pre deatoniate. you can run som crazy boost
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
#19
Re: Re: Re: Torque vs. Horsepower
And what could you possibly know about Diesel engines Mr. Andy? Kidding , Just for those who don't know... Hypsi87 works for Catepillar and all those big ol diesels.
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
#20
well my frickin bad... geez, im not a certified diesel mechanic sorry. but i said 23:1 or whatever... i have heard of that in diesel engines b4. atleast i was partially right... or atleast i think |
#21
Re: Re: Re: Re: Torque vs. Horsepower
ez killer, I did not mean to be an ass about it. Remember, this is the internet.... Can't really show emoition.
