Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-31-2002, 06:19 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Did you listen to anything Bracer Setanta and I said!!
USE THE CAP FROM THE DEL SOL VTEC!!! IT WILL LOOK DIFFERENT!
ITS MENT TO LOOK DIFFERNT!
THE OLD STYLE ONES ARE PRONE TO CRACKING WHICH IS WHAT YOUR PROBLEM IS!
Old 03-31-2002, 08:22 PM
91zc 91zc is offline
I used a 90-91 integra cap and rotor on my b16a. Rotor looks different than the original one but the cap pretty much looks the same. I have had the cap on for awhile with no problems.
91 civic 4dr
b16a
14.8@94
Old 04-01-2002, 05:56 PM
velocitySiR's Avatar
velocitySiR velocitySiR is offline
Send a message via AIM to velocitySiR
no the bolt holes in the del sol vtec one didn't fit in mine that's why i didn't use it.
formerly "riceboi" back at ph
1990 Crx Si ..b16a1 ...i/h/e ...PYR Racing head..ctr pistons .. ...flywheel ...stage 2 clutch ...3.5 drop on Ground Controls ...Koni adj's all around ... ...mugen kit ...sloppy yellow paint job ...apex'i vafc ...gsr brakes ...gsr seats ...autometer a/f gauge ...and more crap that nobody cares about
Old 04-02-2002, 12:55 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Bolt holes wouldn't match or the locating finger didn't match? The latter was a problem I had until I made a gap in the cap with a soldering iron - bodgy bros at work
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 04-02-2002, 01:32 AM
Moppie's Avatar
Master Connector
its very odd that Bracer and I had no trouble with the later cap and Rotor, but you guys couldnt get it to fit.
Either your both doing something wrong, or you have very early engines, or very odd engines.
I wonder if the cap and rotor from a B20a from the lude would work????
Old 04-02-2002, 01:33 PM
no this new cap is firing fine..... so obviously that isn't the prob of cyl 1 firing.... i'm takin it out and havin a compression test done tonite..i wish it was somthing simple like a cap n rotor, but it looks like it may be a bit more serious. fuck.
