Old 10-29-2005, 03:58 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Clutch Fluid
Well, you wanna bleed from bottom to top, slave first, then master. After installation I like to just leave the bleeder screw out.
Then I fill the res, and leave the top off. Once fluid starts flowing nicely out at the slave bleeder, and the bubbles stop, put the screw in. If you are lucky, it has gravity bled, and the rest will purge just by pumping the pedal a few times.
Air likes to get trapped in bends in lines, and sometimes in the slave, tapping them lightly with a tool can get the air to float out instead of clinging to the surface inside.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
