#16
Re: mobil 1 oil
^from what ive heard and seen, you dont need a flush, its reccomended to do, for competent people we can do it ourselves, but just switchen is not going to hurt anything, like i said b4 there are blended oils, which mix synthetic and patrolium based products
#17
Re: Re: mobil 1 oil
The problem is that after using dino for years, your engine gets a lot of crud in it. The synthetic has a far better cleaning ability than standard oil and when it is added to an engine full of dino crud, the synthetic will break the crud loose. The crud not only gets spread around the engine, but it also mixes with the synthetic and doesn't allow it to protect as good as it should. That is why you should flush when switching. |
#18
I'v said it before!!!!! DO NOT PUT ANYTHING IN YOUR CRANKCASE OR GASTANK THAT DOES NOT BELONG THERE.....are you trying to fix a problem????or create one??? just put the oil in and your done!!!...simple eh...
#19
Re: mobil 1 oil
well when it is a crank case oil additive, in this case a de gunker, where should i put it? crankcase would be my first suggestion, after reading the directions that told me to first, of corse.
#20
Re: mobil 1 oil
Re: mobil 1 oil
thanks guys, you all are awesome. im gonna get the stuff and do it, its official. thanks again you are all great!
#22
Re: mobil 1 oil
I am currently using Ato-RX for my truck so I can get rid of some of the sludge buildup in my oil system.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#23
I repeat "are you trying to fix or create a problem"what problem is he having that would require an engine flush????dam there are people out there that drive honda's and toyota's for 4hundred thou's plus miles and still know what a engine flush is.
#24
Re: mobil 1 oil
Running a flush through every 100,000 miles is just a way to get rid of any sludge deposits that will start to form and restrict oil flow. Hell, GM uses them and they make the motors.
#25
Re: mobil 1 oil
I don't have that many miles on. It's a 2000 also. Still I am skeptical of any flushes and additives although I've used a few on other cars. I just put in Mobil 1 and a Mobil 1 filter and did it over in a few hundred miles figuring that the syn might clean it up that way. But Synthetic seeps a little on mine. I've noticed oil wet areas and a few drips hanging places that were bone dry with conventional oil. Mostly at the front and back of the engine, not really around the pan. Some people say that's normal. Is that normal for a 5 year old vehicle with some 21,000 miles on it when switching to synthetic?
These are my opinions. I'm not a mechanic. |
#26
Re: mobil 1 oil
Not normal at all.
You can't blame oil for engine seal leaks.
#27
Re: Re: mobil 1 oil
Re: mobil 1 oil
BTW. You can not compare an honda or toyota engine to an american V6....... get real, man. |
#29
Re: mobil 1 oil
Switching to synthetic at that mileage and getting a leak is a sign of a poor seal.
Synthetic will not cause the leak, but will be actually cleaning and sludge around it.
#30
Re: Re: mobil 1 oil
I should have bought a Ford.
