| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
#16
Re: Re: Car dieing after Installs
I'm still having this problem so rather than start a new thread I thought I'd just ask in this one.
![]() '99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed) Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/ Adopt pets in need! http://www.petfinder.com/
#17
Let me get this straight, you are only having problems after disconnecting the battery? And these problems only last for 30 minutes?
If that is true, why not just stop disconnecting your battery? Also, did you replace your negative battery terminal connection yet? You really should do that, improper grounds will cause all kind of really weird problems. I see that all of this started after you did some installs. Do you have access to a logger? Did you remember to plug in your MAS? You aren't venting are you? Did you check for boost leaks? Are all of your connections plugged back in? There could be a lot of reasons why this is happening, but we need to start somewhere.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
#18
What do you mean? I cant just stop disconnecting it. If I'm, say, putting on a boost gauge, I need to take it off. Or for millions of other things.
I havent replaced the connector because it ONLY happens for a little while after I disconnect the battery. ANY other time it's golden, lol. I dont have a logger, no I'm not venting, everything is plugged back in, there may be some boost leaks but i wont be able to check until I get my air tank (I'm poor ). But again, it's only for a while (maybe 5 or so times of pushing the clutch in) after disconnecting. It doesn't seem like that would be a big deal but I've lost power steering while coming to a stop from it dieing, but that only halppened once. So this doesn't happen to anyone else?
#19
On most cars your fuel trims readjust after the power to the ecu is cut. A few people already said that. It should take about ten minutes. No more than thirty. Give your car a few minutes to idle before taking it out after installing something.
On an unrelated note, go buy the battery cable. It's doubtful that's the problem, but it's good to have, and it's cheap. Kragen, Sears, and Napa all sell them as a generic part. When my negative battery cable connection was bad my car died on me and I got hella CELs, which was bad.
I used to own a DSM. Quote:
#20
Alright, I'll cave in and give that battery cable a try eventually.
#21
