Old 03-22-2005, 06:34 PM
dad2kylie dad2kylie is offline
Re: Re: 95s-10 hard starting when warm
Originally Posted by rlith
those are the codes... Sounds like an injector problem... You actually have the 1st revision ODBII. But by all the codes set, it looks like you're dumping fuel. Pull the upper plenum and check for washing.
If I pull the upper plenum and find washing would i replace the injectors to correct the problem?
Old 03-22-2005, 06:52 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
If the passenger side is washed, replace the CPI, if the driver's side is washed, replace the nut kit. If you do replace the CPI, replace the nut kit as a matter of course as they weaken with age... If you have over a 100k on the existing nut kit, replace them while it's open so you don't have to worry about it later.
Old 03-22-2005, 09:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Originally Posted by movin2stereo
Blazer,any idea why mine would do it?I don't have the nice Vortec cover though.
You are having hard starting?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-22-2005, 10:06 PM
Will that work if i take the vortec cover and look through the sensor hole to see if the passenger side is washed?
Old 03-22-2005, 10:07 PM
BlazerLT's Avatar
AF -Advisor
Yes, that will work.
You will smell gas too.
Old 03-23-2005, 06:28 AM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Re: Re: 95s-10 hard starting when warm
Yea as I said when it's cold it fires right.When it's warm sometimes it fires right up,but must of the time it's turns over for 4-6 seconds before it fires.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 03-23-2005, 10:47 AM
BlazerLT's Avatar
AF -Advisor
So when you say "warm", you are talkig about the engine right?
Old 03-23-2005, 12:15 PM
Do you think the fuel pressure regulator could be causing this problem?
Old 03-23-2005, 12:18 PM
BlazerLT's Avatar
AF -Advisor
Yes, but you just don't replace it, you replace the whole injector.
Old 03-23-2005, 05:13 PM
Yes.
Click here
My $12.00 Sunfire
Old 03-24-2005, 08:14 AM
i replaced the regulator and it seems to have resolved the problem
Old 03-24-2005, 08:32 AM
rlith's Avatar
So it was the CPI unit afterall... Glad you found a fix... Hope you replace d the nut kit while you had the plenum open, it will save you from future problems later on.
Old 03-24-2005, 10:13 AM
it seems to have solved the problem thanks for the help
Old 03-24-2005, 09:14 PM
Yes.Is this CPI my problem?Do I even have one?
Click here
My $12.00 Sunfire
Old 03-24-2005, 09:19 PM
rlith's Avatar
No, you have CSFI, similar to CPI but sequentially fired (CPI was discontinued in 95)...If you're running rich one of your injector hoses may be bad. (also causes misfires)
