Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-26-2002, 04:33 PM
ScottG ScottG is offline
Originally posted by Toy4x4Guy
Yeah, alot of those Tacoma guys are pretty extreme. I would never do anything like that to a daily driver. Most of these guys are even still making payments on these vehicles as well. I admire them though, brass balls that's for sure. One took a ton of pictures of him torching off the IFS and grinding down the welds.
Some have gone all out with full exo cage, marlin dual t-cases, SAS, etc on vehicles as new a 1998 models.
I think I saw that flat bed Toyota in the 4 Wheel Adventure magazine put out by 4 Wheel Parts Wholesalers. They did an article about wheeling in the Lano River bottom near Austin, Texas.
Some of the guys on these Xterra boards are pretty extreme. I think in time we will be seeing solid axle swaps. Nissan hasn't had the offroad following Toyota has had, but we seem to be catching up. I'm hoping that by the time I'm ready to do more extreme stuff with my Xterra, there will be more ideas floating around.
The Patrol axle would be awesome if it will work. In the picture wqbang just posted, the pumpkin looks to be on the passener side.
Are those guys cutting the Wagoneer axles to fit a Toyota? I had thought that a Wagoneer was quite a bit wider than a Toyota.
Old 03-26-2002, 08:07 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Can't you just flip the axle over and put in a reverse-cut ring and pinion? Only other issue might be the steering setup, but that may be a simple fix.
Brent
Old 03-26-2002, 08:53 PM
Brent
I don't know. It doesn't sound like that would be a do it yourself job. Currie builds custom reverse rotation Ford 9 inch axles, but they are about $2,500.00.
Old 03-26-2002, 09:00 PM
Toy4x4Guy's Avatar
Toy4x4Guy Toy4x4Guy is offline
Send a message via AIM to Toy4x4Guy
To my knowledge they are not cutting the axle down.
-Toy4x4Guy
Old 03-27-2002, 12:48 PM
FSRBIKER's Avatar
FSRBIKER FSRBIKER is offline
FSRBiker mentioned doing this about a year ago. He was going to swap in a dana 44 from an old Bronco. Has he made any progress?
I have the front dana 44 out of a Scout sitting in my garage, but I don't have the balls to chop up my Xterra.
I read on Voy that the liberty in the picture has a dana 30. I wonder why they didn't use something stronger.
If I did not start EOE it would have been completed by now, it pains me to look at all the parts I bought and not having enough time for the swap. On an upside my wife has been nagging me lately on why I just don't take some vaction time and do the swap...hmmmm What I would not mind is having another well knowledged interested swap candidate give me a hand, for this I would be willing to get them parts for cost and lend them a hand and shop space for their swap.
BTW I have a Dana 44 out of an early Bronco and the plans are to swap the rear diff to a Ford 9" with discs. To upgrade the Nissan axle cost wise is a little ridiculous($450+ for just gears!) and since the rear will be a spring over and you are removing it anyway to do this I figured why not swap in a diff that after everything is completed saved you money...and open up the wheel choice possibilites(5 lug).
Todd AKA FSRBIKER
EOE
www.Extreme4x4Parts.com
Old 03-27-2002, 03:29 PM
warmonger's Avatar
warmonger warmonger is offline
Send a message via AIM to warmonger Send a message via Yahoo to warmonger
FSR,
A couple things to think about. The Nissan axle is as tough as a Ford. Gears may be cheaper, but do you REALLY need gears with a 4.62/1 ratio? Most Jeeps would bust a nut with that gear. If you get as close as you can to that ratio with the front Dana 44, you will have a monstrocity. Your problem is horsepower, not gear ratio. I would save the money and time on the Ford 9" and invest it in an engine combination. If you get the hp up, add in a crawl gear and dual lockers, you will have a serious @#$kicker even with 35" tires! Also, most hard core off-roaders use a 6 lug pattern on their trucks. The reason is for strength with the bigger tires. The extra lug spreads more of the torque applied and reduces the likelihood of busting lugs off. Something to think about.
Gordon "The Warmonger" White
2000 Silver Ice X
Old 03-27-2002, 03:35 PM
wqbang's Avatar
wqbang wqbang is offline
Send a message via Yahoo to wqbang
With the nissan 4.62 ratio in combination with tranny, the Xterra's effective gearing about the same as other 4x4's. Lower gears would be quite effective at retrieving power lost to larger tire diameters.
No matter how much engine power you put in it, it doesn't make a difference if your crawl ratio sucks. 35's would be almost useless offroad (read rock crawling) in the Xterra without gearing to match, regardless of how much HP is on tap.
Old 03-27-2002, 04:01 PM
The problem with using the rear Nissan axle maybe finding gears for the front to match the rear. That 4.62 ratio (or whatever it is- I thought it was 5. something) sounds like an oddball size.
I saw some pictures last night of Currie's high pinion Ford 9 inch for a Jeep TJ. The pumkin is on the driver's side. It looks like it would work for a front swap, but it is unbelievably expensive. With disc brakes, gears, etc. it is over $3,000.00. YIKES!
Old 03-27-2002, 04:09 PM
FSRBIKER's Avatar
Well our transfer case gearing options just might open up in the near future so swapping the rear diff might not be in the cards, I could invest some money into the motor to gain some horsepower which is not a bad idea...especially since my warranty will be just about useless after the swap anyaway. I have to check around again to see if there is a set of gears for the Dana that is close to the stock Nissan gear ratio, I just hate to sink that kind of money into the Nissan gears and then still be limited with locker choices(two fingers and two toes crossed that I have 31 spline axles)
Todd AKA FSRBIKER
EOE
Old 03-27-2002, 04:11 PM
Originally posted by warmonger
FSR,
Wouldn't you have to get exactly the same gears? That is unless you run different size tires front and back to make up for the difference.
My Scout axles have 4.67 gears. I haven't heard of 4.62 for a Dana 44. I would think you would need them to be exactly the same.
Old 03-27-2002, 05:08 PM
wqbang's Avatar
I was mistaken, the H233B (2000-2001) with LSD has 4.636 gears.
Old 03-28-2002, 10:13 AM
warmonger's Avatar
Actually no. Sand draggers use varied gear ratios all the time. They want a different torque level at the front wheels so they commonly put a different gear in the front. If you operate the truck in 4WD on hard pavement it will cause problems. But in slippage-type enviroments it will cause no issue as long as you get close. If you put a 4.56/1 ratio in the Dana and leave the 4.63 in the Nissan H233B, you are close enough that it will not be noticable.
2000 Silver Ice X
