Old 03-10-2005, 08:39 AM
ricksza's Avatar
ricksza ricksza is offline
Re: rear wheel bearing replacement
From what you're describing, it sounds like a balance problem. The vibration in the steering wheel would be the front tires while the vibration in the seat would be the rear. Are you getting the tires spin balanced? When you get the tires balanced again, if you can, watch and see if you have a wobble in one or more of the tires. You might have two problems. If all else fails, try to swap wheels and tires with someone else for a test drive.
Old 03-10-2005, 01:10 PM
hootymo's Avatar
hootymo hootymo is offline
Send a message via AIM to hootymo
ok so the drivetrain cant possibly vibrate the steering wheel then? it feels like a really high speed vibration in the steering wheel, could that be a bearing? cuz i really dont feel it in my butt anymore, im definitely going to get the tires balanced and rotated and if it still does it i will get new tires. any recommendations on a good brand thats cheap? also, i thought all the shops did spin balancing... dont they? its this computerized thing that spins the tires from what i can see... i have them done at wal mart cuz they do a great job. thanks!!!
Old 03-10-2005, 01:17 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
At this point what you should do is to take it over to the dealer and pay for a 1/2 hour diagnostic (about 30 bux). You keep throwing more and more parts at this thing without succsess.
Old 03-10-2005, 03:00 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Have you checked the engine and transmission mounts yet?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-10-2005, 04:48 PM
hootymo's Avatar
what can i do to check them? im not really sure where they are located
Old 03-10-2005, 05:02 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: rear wheel bearing replacement
Where the engine and transmission mount on the frame.
Old 03-10-2005, 05:54 PM
rlith's Avatar
Actually it's a single transmission mount... the mount pad is on the cross member going underneath the tranny.
Old 03-10-2005, 10:12 PM
BlazerLT's Avatar
AF -Advisor
Originally Posted by rlith
Actually it's a single transmission mount... the mount bad is on the cross member going underneath the tranny.
Yes, that could cause the vibration.
Old 03-11-2005, 09:06 AM
Hellbilly Hellbilly is offline
Could be a broken belt in a tire...I had the samething happen to another car i owned and it was a single broken blet in the tire..
Old 04-07-2005, 06:56 PM
hootymo's Avatar
well believe it or not it was my drivers side engine mount! after 6 garages and 2 dealerships, the last dealership was awesome and they guy knew what he was looking for and he found it and the truck rides like new. thanks for all the help!!
Old 12-19-2005, 02:50 AM
hootymo's Avatar
yea well vibration is back, and its now a bad humming between 65 and 75mph. i get to 43mph and i can hear the "resonating" throughout the truck, the 50mph comes and i feel it in the wheel and just gets worse up to 75mph, which is as high as i have gone, and at those speeds it feels like i am getting a massage through the steering wheel, thats how high speed the vibration is. the 65-75mph humming is bad though, im concerned now that something is really wrong. i never did get to replace that passenger side engine mount when i got the drivers side mount done, maybe both mounts are bad again? any ideas here? i am really tired of paying on this truck every month and it still not being right... i always thought blazers werent supposed to ride like shit all the time, especially a 2000 with less than 100,000 miles on it!
Old 12-19-2005, 05:34 AM
rlith's Avatar
Check to see that the bolts on the new motor mount didn't come loose...Did you put them in or did a mechanic?
Old 12-19-2005, 06:33 AM
hootymo's Avatar
the mount was installed by a gm tech at the dealership.
Old 12-19-2005, 06:35 AM
rlith's Avatar
I would take it back then and have them check it again under warranty. That way it won't cost you anything.
Old 12-19-2005, 06:55 AM
hootymo's Avatar
i didnt know i had a warranty...
