Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 04-09-2008, 09:48 AM
SLDART SLDART is offline
Re: NATS 95 primera , immobilser bypass
Originally Posted by nissantech
Hi again. To bypass the NATS system is not an easy job. if you feel you have the mechanical skills than i can tell you how to do it. You will need to remove the glovebox and the heater motor to gain exess to the nats immu (control unit). I have a bypass plug made up i can email you pictures so you know which wires you have to link to bypass the nats system. let me know.
Hi, is there any chance that you can email me with a picture of which wires to link to bypass the nats 1 system. there seems to be no1 able to do it, so i thought a diagram would be beta and we might get somewhere then?! Thanku
Old 05-07-2008, 09:54 AM
beninguern beninguern is offline
Hi there,
My immobiliser has finally stopped working (i used to just press the key fob button over and over again - Nissan Primera '94). I took the advice on this thread and removed the blower motor but could not find the unit. I eventually found it under the ashtray at the base of the central fascia, or at least i found the only box that seems to fit the bill - disconecting it stops the immobiliser light blinking on the dash. It has 10 wires going into it and although i have tried somewhat random combinations, i have not managed to get the car to start. I was wondering if you could explain which wires should be connected together as your 1&2, 5&6, 7&8 doesn't work - besides which i have 10 wires. A description of which wires to connect either by colour markings or by their numbers on the plug that connects them to the control box would be really helpful! thanks!!!
Old 10-02-2008, 08:30 AM
nismo_cass nismo_cass is offline
if anyone including nissan tech who has the diagram to bypass nats 2 i would be much obliged as im now desperate.........can whoever is willing to help me send it via email please [email protected]
Old 11-18-2008, 11:17 AM
blackguy1978 blackguy1978 is offline
Hi, if u still have the pictures of the nat 1 bypass made can do please email to me?I asked for professional help an i was told that this goes together with control system an can not be bypasst.So i saw your article and decided to ask for help.I really wish you could help me.I have a primera 95 model P10.
Old 12-22-2008, 10:58 AM
first_damned first_damned is offline
Can anyone confirm the bypass for Nat1 worked by looping the wires as mentioned above and does anyone have any wiring diagrams/pictures please?
Old 04-03-2009, 03:05 PM
Ashraf786 Ashraf786 is offline
Hi
Could you please help me with the wiring diagram for Nissan Micra K11 as i have already diconnected the Nats Control Module which is near the Engine ECU. But not sure which wire to bo joint together.
Your Help would be very great help to me
Thanks Ash
Old 04-03-2009, 03:12 PM
Hi nissantech
Could you please help me with the wiring diagram for Nats 1 for Nissan Micra K11.
I have already disconnected the Immobilizer Box which is near the Engine ECU. but not sure how to by pass the system.
Thanks Ash
Old 04-24-2009, 09:54 AM
chef01_99 chef01_99 is offline
Hi NissanTech,
I have a problem with my NATS system for a Serena, when i have found the control unit i have 11 wires, which wires do i need to connect to bypass?
Any help would be most usefull.
Karl
Old 07-29-2009, 02:31 PM
paulymilburn paulymilburn is offline
please can you send me the bypass plug, i will give you any information you need to heplp you as this will help me out lots
Thanks
Old 08-16-2009, 10:23 AM
gofast2 gofast2 is offline
Thumbs up Re: NATS 95 primera , immobilser bypass
Hi does any now how to remove nats on a 1995 primera or have any wiring diagrams or pictures if could you please e-mail them to me as been try to sort this problem out for 2 weeks tryed link the pins but don't know what colour cores link to what cheers my email is [email protected]
Old 11-27-2009, 12:08 PM
loopylowla loopylowla is offline
hi, can you please advise on what the colours that should go together
thanks
Old 05-08-2010, 06:40 AM
dizabo dizabo is offline
Originally Posted by nissantech View Post
This has been covered so may times now. NATS 1 ONLY.
Find and remove the NATS immu, behind glove box.
disconnect and link the following wires.
1&2
5&6
7&8
3&4 leave off.
you should now have disconnected your nissan antitheft.
I think i have found the Unit...
On the unit this text is..
28591 2F901
Lucas 5th
52010124A
Is it those wireres that i should connect?
Old 05-15-2010, 04:35 AM
clairo1968 clairo1968 is offline
Unhappy Re: NATS 95 primera , immobilser bypass
I've got a 2005 Nissan Almera Tino - can the Nats1 system be bypassed in the same way. If so, could you email me the picture showing the wiring bypass to [email protected].
My car is currently stuck on my drive immobilised!
Old 01-25-2011, 10:16 AM
rrautoservices1 rrautoservices1 is offline
2004 Nissan Altima
Hello, my name is Austin and I live in Kentucky. The nearest Nissan dealer is 75 miles from me. I wanted to know if I can bypass the NATS system on an 04 Altima, long enough to drive it to the dealer and have it reprogrammed.
Are the instructions the same or similar for the Altima as these other vehicles being discussed or no? The key does not have a blue chip or anything in it. Just a square black head and standard key-shaft.
It has been throwing codes P1610 and P1614 along with a no start condition. Every once in a while, it will in fact start and run indefinitely. Then once you shut the car off, it may or may not start back up again for days. As of lately, it has not started at all.
So does this topic's instructions apply to me?
Old 12-14-2011, 05:47 PM
auqu74 auqu74 is offline
Trying to start my nissan micra and having mega problems my other solution is to try and bypass my nats 1 system can someone please give me a detailed description of how to do this if neccesary please email to [email protected]
EVAP Canister Issues/Possible bypass? sk8injon Engine and Transmission 1 07-25-2009 08:39 AM
bypass air conditioner skycor Cherokee 5 04-02-2009 08:07 PM
Help - Micra k11 bypass nats system davidarnold General Discussion 0 03-29-2009 04:53 PM
NATS immoboliser bypass bottler General 3 01-09-2007 03:45 PM
Primera NATS system problem. xk180 General 0 01-24-2004 09:49 AM
