Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-10-2005, 08:43 AM
Jovian9 Jovian9 is offline
Re: How many miles do you have your Isuzu?
1999
3.2
V6
>60k
Front rotors 3X (in less than a year) d/t warping
front bearings 1X (but repacked 1X after that)
front pads 2X (in less than a year d/t warping)
Intake Gasket
Fuel Sending Unit
Front R Wheel Speed Sensor (front R quarter panel needs replaced d/t a minor accident I had b/c the ABS were too sensitive and went off and I rear ended someone)
Turn Signal Relay
Rear Rotors and Pads (2X)
Serpentine Belt
Idler Pulley (2X in a year)
I forgot the tensioner pulley and spark plugs have been replaced.
...and it seems like the timing belt tensioner is on its way out now
Old 03-10-2005, 10:23 AM
djfreake djfreake is offline
1997 rodeo v6 3.2 100,258 miles
major problems...hmmm well i cant really hold my bladder all that well anymore(apparently comes with age) and my back is killing me...other than that all is good
Old 03-10-2005, 06:59 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
296,000 MILES
bought with 267,000 had seized engine looked as if it were poorly maintained
installed engine with 50,000 miles running great
replaced trans after wife burnt it climbing mountains in overdrive (imagine that) it was a long road trip to AK I was sleeping and never thought to tell her to tak it out of OD when we hit the hills we live on flat land and dont usually see mountains so she just did not know junkyard tranny with 100,000 holding up well
KEEP UP WITH MAINTENANCE AND THEY WILL LAST
Old 03-10-2005, 10:44 PM
heritage72 heritage72 is offline
1996 Rodeo
156,000 miles
New starter and brakes (2 sets).
Old 03-11-2005, 05:05 PM
96rodeo 96rodeo is offline
3.2L V6 4x4
142,000 miles
Absolutlely no major problems. My Rodeo has been reliable, dependable, and tough as nails! I love this truck!!!
Oh yeah, I'm a fanatic about the oil changes, replacing it at 3k or a little sooner! Plus I've stayed on top of all the tune ups and services. This has included over the life of the truck: replacing all the fluids, filters, spark plugs, PCV valve, timing and accessory belts (tensioner as well), thermostat, shocks, all 4 CV Boots, cleaning and repacking both CV axles, brake pads and rotors, switching to Bridgestone Dueler A/T Revos, and other things that I can't remember.
My Rodeo runs great, looks great, and isn't slowing down a bit!!!
-Nick
1996 Isuzu Rodeo; 4X4; 3.2L; 140K miles and counting!!!
Old 03-12-2005, 06:53 PM
DCMoose48 DCMoose48 is offline
Send a message via AIM to DCMoose48 Send a message via Yahoo to DCMoose48
1994 4x2
2.6L 4cyl
shows 224k but previous owner says probably over 300k
no idea about major problems
I just got my Rodeo in the last week from a guy I work with for $200....... now I just need to learn to drive it (stick shift)......
Old 03-13-2005, 07:24 AM
Super 95.5 Rodeo Super 95.5 Rodeo is offline
Send a message via AIM to Super 95.5 Rodeo
Year: 1995.5 Rodeo 4WD
Engine: 3.2L V6
Mileage: 247542 miles
Problems: No major problems. Routine maint. like replacing timing belt, water pump etc. Takes a lickin' and keeps on tickin'
Brian Creelman
MSgt USAF Reserve, Retired
1995.5 Isuzu Rodeo S 4WD 3.2L V6 247542 miles
2004 Ford F-250 Super Duty Crew 6.0 Diesel
2006 Ford Mustang GT Coupe Tungsten Grey
Old 03-14-2005, 01:21 PM
phil73 phil73 is offline
Year: 2001 Rodeo 4WD (canadian)
Engine: 3.2L V6
Mileage: 47 000 miles
Problems: MAJOR oil cusumption problem since 16000 miles, rebuild the motor at 40 000 miles (they drilled additionnal holes in the pistons), since nothing...
Old 03-15-2005, 01:08 AM
jumanjii1 jumanjii1 is offline
Red face
Year: 1993
Engine: 3.2 V6
Mileage: 160,000
Any major problems: Replaced Timing Belt, Idler, Tensioner, Adjuster, Water Pump, Accessory Belts. Got it from my brother which his daughter drove (not much maintenance) Still running strong though. Got it on a diet of Mobil 1 so that should stop the wear. Been leaking Anti-Freeze from behind the engine (cross over line?) since the 1st owner had it but appears to be getting worse now. What's it cost to fix?
Old 03-15-2005, 12:10 PM
SilverLS SilverLS is offline
1999
3.2L V6 2WD
125,000
No "major" problems, but quite a few "minor" ones such as:
fuel sending unit
intake manifold
clutch fan
egr (finally replaced after cleaning many times)
front axle bearing
Old 03-15-2005, 01:50 PM
RONSTOO RONSTOO is offline
335000 I I have 91 Rodeo V-6
Old 03-16-2005, 12:26 AM
bighops2000 bighops2000 is offline
Send a message via AIM to bighops2000 Send a message via Yahoo to bighops2000
95 3.2 V6
160k
engine ticks like a champ
Old 03-20-2005, 10:26 AM
fishmonster13 fishmonster13 is offline
1996 v6 127000 just bought it ,has no heat yet and the cel is on needs new shocks , other than that it runs great
Old 03-21-2005, 09:30 PM
surferfletch surferfletch is offline
1997
3.2L V6
140,000 miles
One window regulator. CD changer just broke. Fluids done on schedule. Needs valve cover gaskets and spark plug sleeves. Also due for another t-belt, water pump, etc.
Old 03-22-2005, 06:55 PM
cavyshack cavyshack is offline
92
3.1L
110000
rearerend went,needed tune up nuthin big,valve covers,clutch went thats it i guess
