Old 03-08-2005, 12:12 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Adjustable Coilovers??
I get my tax back when I rent from Autozone.
So I guess i'm gonna go with the adjustable coilovers then.
what to look for to tell if you need an alignment:
-does your car pull when driving and the steering wheel is straight when you let go?
-are your tires wearing evenly across? no slope, one side worn more than the other, no flat spots?
-if you let go of the wheel when your driving on a flat surface does the steering wheel turn itself ?
Answer those questions, if any of those things occur you should consider an alignment. You should also ALWAYS get an alignment if you upsize your rims/tires, change ride height, or hit a pothole really hard.
Igovert500's Avatar
blue + red light magnet
Thourun, how much the alignment cost ya?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-08-2005, 06:54 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
$89... ouch. But now I get free balancing and rotation and pressure checking whenever I want for the life of the tires.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
