Old 03-31-2002, 08:14 PM
brads94accord brads94accord is offline
Send a message via ICQ to brads94accord Send a message via AIM to brads94accord
Re: how many washers???
Originally posted by strodda
ok, hopefully a simple question. 1.8" rear drop. how many washers would i need to "mostly" correct the camber. im not looking for perfect, but i dont wanna have to buy new tires every year either.
im thinking two washers will do just fine. i have two in my back and its still off a little but not enough to cause tire wear.
representin old school ph since april 2001, formerly UGAbrad94Accord
311 rules!
94 accord lx
16" konig reigns
3.25 inch drop on sprints and bec-techs.
clears all around, intake, custom rear section exhaust
farenheight plasma xenon headlights
click for my website
Old 03-31-2002, 09:24 PM
strodda strodda is offline
Originally posted by twizzaut
all i used to fix the camber in back of my car was some washers
how much is it lowered?? and how many washers did you use?
Old 04-07-2002, 04:36 PM
Dahmin8's Avatar
Dahmin8 Dahmin8 is offline
I've got Neuspeed Sport springs on my 90 LX. That's 1.8" in the front and 1.7" in the rear. I've a Progressive Camber kit in the front and didn't have to use any washers that came with the kit the I bought in the rear. I'm currently rolling on 17" Giovanna Chibas. I also have front and rear Suspension Tech sway bars. I am not certain if the sway bars helped, but when I got my alignment the rear was damn near perfect also. So I didn't need the extra washer in the rear because the car isn't dropped far enough to matter. Hope this helps.
Dahmin8 90 Accord LX
Old 04-07-2002, 05:38 PM
on the rear kit, did you keep the stock bolts? and if not, does using the kits bolts(even without washers) extend the arm out at all? the springs i got are 1.8, so if im lucky maybe i wont need one either.
Old 04-07-2002, 07:19 PM
Dahmin8's Avatar
The bolts in my kit were longer. It won't make a difference. My stock bolts are still in. I'm sure that your stock bolts will do just fine. The longer bolts are used to compensate for the extra distance caused by the washers when installed. You probably could use the stock bolts when using the washers. I guess to justify the cost of the rear camber kit most of the manufacturers have to supply you with something for the money. I would just install whatever camber kit that you have purchased in the front. Then have your alignment checked to find out what is needed. The shop that I went to, didn't need to adjust my rears at all. The front only needed a little tweeking. Also, with a static kit you have to install them correctly. You have a 50 - 50 chance to get it right or wrong. Don't worry though if it's incorrect your front upper control arm will hit. If it's correct you shouldn't hear a sound. I do however recommend going with the adjustable camber kit. It does seem to be easier to adjust, instead of tearing everything apart again to correct an error in the install. The good thing about the static thogh is once you're right, you're done. Unless you want to go lower than they are recommended for.
Old 04-07-2002, 09:44 PM
yea i got a ingalls kit already for the front. adjustable of course ive just been really damn lazy and havent installed them yet. and i gotta make an apointment at the shop, and they said theyd add washers if necessary, as part of the alignment charge.
who knows when ill finally get it all done, get new tires, and put my rims back on. but ill be sure to get a pic up when its all done.
and thanks for all the help
Old 04-07-2002, 09:47 PM
one more thing, do you have any pics of your rear wheels? i know itll be ok driving straight, but im worried about rubbing when i hit a bump or something. i have 215/45's, did you have to roll the fender at all?
Old 04-08-2002, 07:04 AM
Dahmin8's Avatar
Your tires are bigger than mine. I didn't have to roll the fenders at all.
In the rear I believe you will need to worry about the control arm rubbing the top of your tires. What is the offset on your rims. Offset of your rims will determine alot.
I hope this pic helps.
How do you install a rear camber kit on 05 accord coupe noweighjose How-To's and Walk-Through's 3 09-22-2007 11:29 AM
Rear Camber Kit androsvalentino Aurora 3 02-01-2006 06:56 AM
looking for a rear camber kit....... honda_vtech94 Accord/TSX/Accord Hybrid 2 03-14-2005 01:05 AM
rear camber kit for a 1998 benz slk myellowslk Tires and Wheels 3 08-06-2003 12:42 PM
