#16
Re: Exhaust makes 'popping' noise when i let off the gas
Just means some gas got past the headers and cats and is not igniting till way back in the exhaust. Mine doesn't do it unless i was just on the gas reall heavy.
![]() R.I.P. Andy, A great guy and an even better friend. 2000 Z28 A4: Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires. Buried Needle Racing!!! |
#17
Im glad someone else asked this question. I just installed headers and a a 3" flowmaster and mine does the exact same thing. Popping after hard excelleration. I thought I screwed something up or found another problem.
#18
my car does that too. i have a 2.8 6cyl....... with flo masters, everything is stock except the flow masters, but it only pops when its not warmed up, sometimes if i downshift, but like you guys said if its unburned fuel getting to the cats or muffler, think its bad spark plugs, wires, and cap and rotor?
Nah stuff like this happens after hard acceleration cause u are pulling in all this fuel then u suddently cut it off so some of it will get through.
#20
Re: Re: Exhaust makes 'popping' noise when i let off the gas
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
#21
im thinking hooker for headers and borla for the exhaust
![]() Quote:
#22
Hookers are ok, they have to be clean tho
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
#23
yeah and at the same time its not my final answer, im still looking at other headers to see whats going to give me the most for my dollar, but borla is going on thats a no-brainer.
![]() Quote:
#24
Um... where did you find hooker headers for the 3.8?!
I thought we were limited to CIA, Pacesetter and RKSport
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
#25
the popping noise is from a lack of backpressure. all the vaccumm lines and emmission control stuff under the hood is set up for the stocl car specs. when you put headers or aftermarket exhaust you change the flow rate of the exhaust and that results in lesss back pressure causing the popping.
#26
I will update on if is goes away when I get HPTuners done which will hopefully be this coming weekend
#27
im not sure about all the others except for lt1 but expecially the thirdgen, this doesnt apply to...
the poping is from something like extra gas that isnt burned after letting off the pedal. i dont know about the technical side of it but the way i helped reduce it to the point that i can not notice it on my lt1 is i disabled the air pump. the air pump puts air into the exhaust to get rid of moisture i beilive. disableing this doesnt hurt anything at all and can be disabled on an lt1 by disconecting the cable right under the air pump in front of the engine, close to optispark. it will have a purple connector on one side... im not positive but i think the air pump comes on the first 4 mintues of engine run time and then every time you let off the gas hard. regardless after unplugging the air pump the thing revs down sounding smooth and all... no poping or cracking... it has nothing to do with backpressure, and getting the headers and freeer flowing exhaust only makes it worse... |
#28
#29
The exhaust has nothing to do with the source of the popping/cracking, but it only makes it more noticable as the restriction in the exhaust is less and it gets louder. and about the 3.8's that why i said i wasnt sure for anything except the lt1... EDIT: i was looking on other forums and it looks like you guys are on your own, i havent seen anything about the 3.8 having that happen... good luck... Last edited by tc3; 03-07-2005 at 11:31 AM. |
#30
which other forums?
