#16
Re: Re: Blow Off Valve...
I meant your avatar
#17
i thought it goes on the pipe from the IC to the Intake?
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
#18
Oh.. Its a 90 Civic HB Si
#19
Re: Re: Re: Blow Off Valve...
yep...it doesn't go anywhere near the turbo...actually it goes closer to the throttle body.
I said a blow off.. but its as .. Air Breather
#21
theres a big difference between blow off valve and air breather filter. lol
its all good tho |
#23
Re: Re: Re: Re: Blow Off Valve...
The reason why you want it closer to the TB is so that that when you let off the gas and your butterfly valve closes in the TB, your BOV will open and release the pressure in the charge pipes so your turbo doesn't keep pumping air into your butterfly valve and bend it in half when it's closed (and of course stop sending compressed air into the engine too). Technically, you can put it anywhere on your charge pipes between the intercooler and the TB, but the close to the TB the better so that the pressure closest to the TB will release the quickest and no damage will be done.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete) www.naytontech.com :: youtube.com/naytontech |
#25
theres not gonna be any damage to your tb. bend the throttle plate, yeah right. the only damage that can come of getting off the throttle is to the turbo through compressor surge. so by your guys own definition, you would want it closer to the turbo.
the idea of the bov is to protect the turbo so is the ideal place farthest away from the turbo it can get? or would it be better to put the bov near the turbo so protect any boost from going into it backwards. because at the tb boost near the compressor might go back into the compressor, so if you have it near the compressor it will make sure no boost goes into the compressor |
#26
Yeah.. But what does a Air Breather do....
#27
basically...it pushes all the air out from your head. there is a hose on ur head that goes from your head to your intake. if you take off the hose the breather filter goes on the head.
