Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-10-2005, 05:27 AM
computerdude14 computerdude14 is offline
Re: Gas Mileage?
Originally Posted by jdrumstik
gee Im getting about 20mpg with a lot of hiqways too on my 88 si, and i get my arir filter changed on every oil change wich is ussally at about every 2500 miles since something breaks.
Anyways, maybe im a victim of a fuel filter. Is there a way to check it or just get it replaced.
And how much should a shop charge for that?
2 things. first of all, i donno if its any different in ur 88 lude than it is in my 91 si, but in mine the fuel filter is fairly easy to get to. id just do it myself if it was up to me. but id guess that a shop shouldnt charge more than like $40 or $50 im guessing. and 2ndly, there is no way to check it unless you have a fuel pressure tester. then you would test pressure be4 the filter and pressure after the filter, see if its out of specs. you can look up the specs in the service manual. peace!
mike
Old 03-10-2005, 06:06 PM
Gohan Ryu Gohan Ryu is offline
Re: Re: Re: Gas Mileage?
26 mpg and you're not happy? Maybe you should go hybrid!
Originally Posted by vtecludeguy
seriously dude... CAI does not make you burn more fuel. if you burn more fuel, it's b/c you're injecting more fuel into the cylinder... but you're not. since cold air is denser than warm air, there is more oxygen in it causing a bigger combustion. Thus, you’re getting more horsepower with the same or better fuel economy.
Don't tell me, tell the other guy!
Old 03-10-2005, 06:25 PM
Unconnected Unconnected is offline
Welp, I just found a thread with everybody elses gas mileage, im right there in the middle, if not, upper end. So i'm a little happier..
Well now that this problems solved, on to the million other ones
Old 03-10-2005, 11:08 PM
vtecludeguy vtecludeguy is offline
Re: Re: Re: Re: Gas Mileage?
oh, i was just agreeing with you.
